[GRASS-user] [GRASSLIST:1194] v.distance to_angle is always zero
when using v.distance on two vectors containing a single point, the 'to_angle' value is always 0. Does anyone know why? For example:
v.distance from=pt1 to=pt2 out=test_line upload='dist,to_angle' column='dist,to_angle' -p --overwrite
gives the following:
from_cat | dist | to_angle
3|162955.770760|0.000000
Statistics:
0 categories with more than 1 feature in 'from'
0 categories - no nearest feature found
Building topology for test_lines ...
Building topology ...
1 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 2
Number of primitives: 1
Number of points : 0
Number of lines : 1
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
