[GRASS-user] [GRASSLIST:1202] d.rast
Hello all,
since I did a cvs-update yesterday I cannot display any raster files any more.
GRASS 6.3.cvs (airfield):~ > d.rast map=PisteFotoRect -o
WARNUNG: No socket to connect to for monitor <x0>.
FEHLER: Keine Graphik-Ausgabe ausgewählt.
d.vect does work normal... Any idea?
Greetings from black forest,
Jochen
Jochen Gaedcke
Tutschfelder Str. 9
77955 Ettenheim
Tel.: +49 7822 5342
dear nisith,
sorry, I did not mention this is a 6.3 problem. 6.2 works fine.
If I start a monitor before I get a memory access error.
cheers, Jochen
Am Donnerstag, 10. Mai 2007 05:16 schrieb nishith datta:
hi jochen,
Do we assume you have started a monitor with *d.mon start=x0* or *d.mon x0,
*before trying
to open the map in the display. X0 is the active monitor where you want the
display to appear.Replace with a suitable monitor upto x7, as reqd.
At least your error , no socket to connect to suggest that the monitor is
not open.
Thanks
nishith
Hi Jochen,
last night a problem was fixed in XDRIVER. Maybe it cures your
problem, too (6.3-CVS).
On Thu, May 10, 2007 at 11:07:22AM +0200, Jochen gaedcke wrote:
dear nisith,
cheers, Jochen
> hi jochen,
> *before trying
> not open.
> Thanks
> nishith
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
