[GRASS-user] grib format data import problem with GRASS 6.5
All:
I have built GRASS 6.5 svn (2010_04_10) with fftw, proj4, gdal (1.7.1), sqlite, postgresql, tcltk,… When I try to import a grib2 file using r.in.gdal I get a message that the file is not a supported format. Running gdal-config --formats shows that grib is supported.
If I run on another machine, with a separate installation, but with GRASS 6.4, on the same grib file, it imports without problems and I get what I expect. Is there anything I should look for to help identify what's going on with my GRASS 6.5 installation? I have been struggling with this for several days and I am befuddled…
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
generic gdal problems advice:
* check that gdalinfo can read it
* check the gdal bug tracker for GRIB bugs (including fixed)
* check the version of gdal on both machines
* check the gdal release notes for mentions of GRIB things fixed/changed
in general, if GDAL can't read it then GRASS can't either, and import
errors with r.in.gdal are often completely independent of the GRASS side
of things.
if GDAL can't read it with its internal utilities (gdalinfo, gdal_translate)
then the best route is to ask for help on the gdal-dev mailing list.
if they can, it's probably a GRASS bug.
regards,
Hamish
