[GRASS-user] Grid label format in psmap
I have a UTM dataset that I am plotting with psmap. I would like to have grid squares at 1000 m intervals. I can do this easily with the following:
grid 1000
    color black
    numbers 1
    font helvetica
    fontsize 12
end*
*However, on the resulting plot, the gridline labels are truncated into kilometers e.g. 498, 7114, instead of 498000, 7114000. Is there a parameter that I can modify somewhere so that I can control output format and display the full number. (Similar to D_FORMAT / OUTPUT_DEGREE_FORMAT in GMT, I suppose).
John
Dr John A Stevenson
RSE/Scottish Government Personal Research Fellow
(co-funded by Marie Curie Actions)
School of GeoSciences
The University of Edinburgh
Grant Institute
West Mains Road
Edinburgh EH9 3JW
Scotland
PHONE: (+44) 131 650 7526
FAX: (+44) 131 668 3184
email: john.stevenson@ed.ac.uk
web: http://www.geos.ed.ac.uk/homes/jsteven5
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
On Thu, 25 Nov 2010, John A Stevenson wrote:
grid 1000
  color black
  numbers 1
  font helvetica
  fontsize 12
end*
John,
   Have you tried specifying grid 1 (assuming kilometers rather than meters)?
If so, what results did you see in the pdf?
Rich
grid 1000
color black
numbers 1
font helvetica
fontsize 12
end*
right, it automatically truncates off extra zeros. I usually
use the map_info instruction which shows the full bounds.
Unfortunately there's no way to switch off that feature without
modifying the source code. if you wish to do that, edit
ps/ps.map/do_grid.c and in the do_grid_numbers() function
edit this line -from, +to:
- sprintf(num_text, "%s", format_northing(g, rounded_grid));
+ sprintf(num_text, "%s", format_northing(g, 1));
and then recompile. (untested)
you may also try out ps.output from the Addons collection, it
has more advanced border controls:
  http://grass.osgeo.org/screenshots/images/probabilidad_de_infeccion_crop.jpg
(which at some point will be merged into ps.map too)
Hamish
