I am using gstat within grass to calculate variograms. It works very well in UTM locations, but now I need to use it in a lat-long location, which it doesn't support. I am trying to think of a way round this and decided on the following strategy:
1- export the data to a text file (r.stats -1g)
2 - reproject the data in the text file to UTM (cs2cs)
3 - use gstat to calculate the variogram of the text file
This method works, provided that I run gstat outside of GRASS. However, I would now like to run these calculations from a batch file. I can imagine two ways of doing this, and these are my questions:
Option 1: Trick gstat so that it thinks that it is running outside of GRASS so that it will let me input my data from a text file. I tried unsetting some of the GRASS variables but this didn't work. Is there a way that I can do this?
Option 2: Get my shell script to exit from GRASS, run the gstat commands, then return to GRASS where it left off. Is this way possible? Alternatively, if I could get GRASS to run commands as if from another shell then that may work, too.
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
