[GRASS-user] GTiff export
Dylan et. al, Can I encourage people to add the kind of information in your website the grass frequently asked questions section? Your link is to a web page that looks like a really useful set of directions but would be hard for outsiders to find.
Just a thought.
Jerry
---- Original message ----
Date: Mon, 18 Dec 2006 11:13:05 -0800
Subject: Re: [GRASS-user] GTiff export
To: grassuser@grass.itc.it
On Monday 18 December 2006 08:05, Raffaele Morelli wrote:
I got two raster files imported in Grass using r.in.gdal, one represents a
dem, the other is a "drape". (the files originated from ArcGIS)
I am setting up a WebGis app (apache, mapserver, php_mapscript) and need a
tiff layer to represent elevation and have a image background to put my
vectors/points on.
I tried to export the dem file with r.out.gdal, but I obtain something
similar to a negative a b/w image with no colors!
Tried several 'createopt' but still with no success.
With Grass6.2 everything looks fine.
Whats' wrong? Should I merge the two raster files first?
I am not a "GIS geek" so any kind of help will be appreciate.
thanx
raffaele
I have had similar problems in the past. Here are some ideas that I posted a
while back:
http://casoilresource.lawr.ucdavis.edu/drupal/node/337
Note that r.out.gdal has been updated since I posted these notes. Also- I have
had the best luck using arcinfo (command line) directly to import geotiff
files:
imagegrid * * * *
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
grassuser mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Jerry,
Indeed. I feel the same way. i will work toward migrating much of my notes to
the GRASS wiki in the near future!
cheers,
dylan
Just a thought.
Jerry
>From: Dylan Beaudette <dylan.beaudette@gmail.com>
>> Hi,
>> a dem, the other is a "drape". (the files originated from ArcGIS) I am
>> vectors/points on.
>> thanx
>> raffaele
>Hi,
> a while back:
> have had the best luck using arcinfo (command line) directly to import
> geotiff files:
>imagegrid * * * *
>cheers,
>Dylan Beaudette
>530.754.7341
>_______________________________________________
Gerald Nelson
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Dylan Beaudette
530.754.7341
>posted a while back:
-co COMPRESS=DEFLATE \
fwiw, I needed to use COMPRESS=PACKBITS to get ArcView 3.1 to read a
GeoTIFF made with r.out.gdal.
see also the r.out.arc help page examples.
Hamish
