On Sat, May 31, 2008 at 10:21 AM, Michael Barton <michael.barton@asu.edu> wrote:
It will be
difficult for beginners (who never worked on Linux/Unix and in Command
Line CUI mode) to GRASS to work with X-monitor (Monitor X0) and Map
Display 1.I don't understand this at all. You have the equivalent FUNCTIONS in the
GUI,
As I came to know from above discussion, it is not available for all
such commands in category d.*
<snip>
Instead of running d.rast from the command line to display in an x-monitor,
you add a raster map to the GUI layer manager and press the display button.IMHO, this is considerably easier for beginners to do than to run commands.
Only for this reason, I want develop a tutorial using GUI only. That's
where I am facing problems, and I started this thread. Otherwise for
me, commands in terminal window rules. I am putting this effort to
attract beginners.
Have you actually TRIED either the TclTk or wxPython GUId???
Yes. I only post on mailing list, after trying at my level best to
find the solution at my level.
I appreciate help rendered by you all nice GRASSians!
H.S.Rai
http://hs.raiandrai.com/
