[GRASS-user] GUI equivalent of command
Mr. Rai,
First, which version of GRASS are you using? The GUI in the current GRASS
6.3.0 works with a TclTk canvas, not an x-mon (e.g., x0). If you are using
an old version of GRASS, I highly recommend that you upgrade to 6.3.
Second, if you want to interact with a display--show a map, interactively
query a map, etc--you need to do so through the GUI, not by running d.*
commands. GRASS display commands (d.rast, d.what.rast, etc) will not work in
the GUI display without a lot of programming. Instead, use the buttons on
the display toolbar for zooming, querying, profiling, etc.
There is pretty good on-line help for the GUI. Look at GIS Manager help
under the Help menu in the main GUI window. This should be a good start for
your tutorial.
I hope this helps.
Michael
On 5/31/08 8:13 AM, "grass-user-request@lists.osgeo.org"
<grass-user-request@lists.osgeo.org> wrote:
Date: Sat, 31 May 2008 10:50:31 +0530
Subject: Re: [GRASS-user] GUI equivalent of command
To: "GRASS user list" <grass-user@lists.osgeo.org>
Message-ID:
<e46836620805302220w3c1eb1c0pd0eeb4613d93af47@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
On Sat, May 31, 2008 at 10:21 AM, Michael Barton <michael.barton@asu.edu>
wrote:
It will be
difficult for beginners (who never worked on Linux/Unix and in Command
Line CUI mode) to GRASS to work with X-monitor (Monitor X0) and Map
Display 1.
I don't understand this at all. You have the equivalent FUNCTIONS in the
GUI,
As I came to know from above discussion, it is not available for all
such commands in category d.*
<snip>
Instead of running d.rast from the command line to display in an x-monitor,
you add a raster map to the GUI layer manager and press the display button.
IMHO, this is considerably easier for beginners to do than to run commands.
Only for this reason, I want develop a tutorial using GUI only. That's
where I am facing problems, and I started this thread. Otherwise for
me, commands in terminal window rules. I am putting this effort to
attract beginners.
Have you actually TRIED either the TclTk or wxPython GUId???
Yes. I only post on mailing list, after trying at my level best to
find the solution at my level.
I appreciate help rendered by you all nice GRASSians!
H.S.Rai
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
On Sat, May 31, 2008 at 8:56 PM, Michael Barton <michael.barton@asu.edu> wrote:
GRASS6.2.2, which is default in Ubuntu Linux 8.04 (Hardy Heron).
Will try just now.
I have experimented with all buttons of 6.2.2, will revert back about
my experience with 6.3 shortly.
your tutorial.
Thanks for your advise and help.
H.S.Rai
You can get 6.3 from here:
http://www.les-ejk.cz/ubuntu/
Moritz
Here is effort to give mouse stroke to work in GUI, if someone knows
the command.
   http://spreadsheets.google.com/pub?key=pB-ffIn4C2dTcTacV_W1cOA
Let me know, if something is missing there.
H.S.Rai
http://hs.raiandrai.com/
