On Sep 29, 2009, at 5:14 AM, grass-user-request@lists.osgeo.org wrote:
Date: Tue, 29 Sep 2009 07:07:24 -0400
Subject: [GRASS-user] GUI freeze when trying to change legend
To: grass-user@lists.osgeo.org
Message-ID:
<b440a3f80909290407g61ffa161iaa933697ec9d1afb@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1Dear Grass,
I am having a problem when I try to change the legend for my raster
file using to GUI. This happens even if I select a new legend to add.
As soon as I select the raster map from the list Grass freezes for
several minutes.Perhaps it is a problem with the raster file or the rules file,
however it runs fine when I run the command in the terminal. I would
like to do this in the GUI since I am not sure how to do all of my map
resizing and saving as .tif from the command line.Can someone please advise me on this?
I am using Grass 6.4 with standard GUI (not Python)
System is Mac OS 10.6.1Thanks in advance for your time,
Michael
I see that you are using Snow Leopard, which has Python 2.5.1 and 2.6 on it. It can also have a couple different wxpython versions. William Kyngesburye has worked out special instructions for compiling on Snow Leopard.
If you are not using a recently compiled binary (after mid-September), you will have problems.
My guess is that this is related to ticket: http://trac.osgeo.org/grass/ticket/753. This is caused when you compile GRASS with more than one version of python on your Mac. In these circumstances, there is an error in a display widget (PseudoDC). The whole issue is complicated but I can explain more if you are interested in the intricacies of the code.
The fixes are to either
1) find the second version of Python and any vestiges of a second wxpython and delete them (sometimes harder than it seems, and especially complicated with Snow Leopard with needs 2 official Python versions), make distclean, and recompile. Or
2) bundle wxpython with GRASS.
The second option guarantees that you are running with the version of wxpython that you compiled with and that all parts of GRASS are using the same wxpython. I'm recommending bundling wxpython with all Mac binaries to avoid this and other problems.
Michael
