[GRASS-user] gui modeler: dynamic variable names
I'm experimenting with the gui modeler (thanks for a great tool by the way !) trying to build a very simple model of city growth, starting with a very basic cellula automata style model where the state of each pixel at time t+1 depends the state of its neighborhood at time t.
In Python the result is as follows:
     for map in range(1995,2005):
         grass.run_command("r.neighbors",
                           overwrite = True,
                           input = "city",
                           output = "tmp1",
                           method = "sum",
                           size = 3)
         grass.run_command("r.mapcalculator",
                           overwrite = True,
                           amap = "city",
                           bmap = "tmp1",
                           formula = "if(A==0 && B>4, 1, A)",
                           outfile = "city",
                           help = "-")
Now I would like to keep each of the intermediate steps, and so create mapnames dynamically with the year in the map name. In Python I can do this like this:
                           overwrite = True,
                           input = "city_"+str(map),
                           output = "tmp1",
                           method = "sum",
                           size = 3)
                           overwrite = True,
                           amap = "city_"+str(map),
                           bmap = "tmp1",
                           outfile = "city_"+str(map+1),
                           help = "-")
but is there a way to do this in the modeller directly ?
Moritz
