Hi again!
sorry for bothering with two posts on my first day here
just in case somebody has experienced the same..
while starting grass, I get this message:
grcscaini@cscaini-Latitude-E6420:~$ grass
Cleaning up temporary files ...
Starting GRASS ...
ERROR: G_getenv(): Variable LOCATION_NAME not set
File "/usr/lib/grass64/etc/wxpython/gis_set.py", line 1002, in <module>
GRASSStartUp = StartUp(0)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/usr/lib/grass64/etc/wxpython/gis_set.py", line 977, in OnInit
StartUp = GRASSStartup()
File "/usr/lib/grass64/etc/wxpython/gis_set.py", line 171, in __init__
self._set_properties()
File "/usr/lib/grass64/etc/wxpython/gis_set.py", line 221, in _set_properties
not os.path.isdir(os.path.join(self.gisdbase, location)):
File "/usr/lib/python2.7/posixpath.py", line 66, in join
if b.startswith('/'):
AttributeError: 'NoneType' object has no attribute 'startswith'
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
it is a while (3-4 weeks) bus I usually work with script so I do not use the GUI
but I would possibly do it soon using the d.out.file... I tried it but I cannot enable the graphic display wiht d.mon so maybe something weird is happening in my computer...
I work on Ubuntu 12.04
is anybody experiencing the same?
thanks a lot for your time and help
chiara
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
