I am using Grass6.3 and the tcltk-GUI:
When displaying a vector layer, the 'query vectors for display' allows to provide a SQL query.
How can a SQL query of the following kind be entered ?
'my_integer_attribute IN (4,7,19,345,678,111)'
Using "IN" as described above results in an error:
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected NAME processing 'IN'
in statement:
SELECT cat FROM country_FOO WHERE FOO_ID IN (2238509,3358510,445812)
Error in db_open_select_cursor()
Using an OR-construction as in
attribute=4 OR attribute=7 OR attribute=19 OR ...
gets pretty soon tedious.
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
Neu: GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate + Telefonanschluss für nur 17,95 Euro/mtl.!* http://dslspecial.gmx.de/freedsl-surfflat/?ac=OM.AD.PD003K11308T4569a
