[GRASS-user] HDF-5 parse
Hello Pedro
My suggestion, in case you have a consistent dataset, would be to create your own script to read import HDF5 files. My question regarding this is it possible to have a "Browse files" button in a GRASS scripts?
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4872 (20100216) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Thank you all.
Regarding Antonio’s suggestion I will see if I can do that. It seems a good Idea. Is it possible to have a button to browse files?
Thanks
Best regards
Pedro
2010/2/17 António Rocha <antonio.rocha@deimos.com.pt>
Hello Pedro
My suggestion, in case you have a consistent dataset, would be to create your own script to read import HDF5 files. My question regarding this is it possible to have a “Browse files” button in a GRASS scripts?
Antonio
http://www.eset.com
Hello all
Regarding this question, I’m using a MSG SEVIRI product called FAPAR. And I’m a bit lost on import data to GRASS and rectify.
By making gldainfo I get:
Driver: HDF5/Hierarchical Data Format Release 5
Files: /mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000
Size is 512, 512
Coordinate System is `’
Subdatasets:
SUBDATASET_1_NAME=HDF5:“/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000”://FAPAR
SUBDATASET_1_DESC=[651x1701] //FAPAR (8-bit integer)
SUBDATASET_2_NAME=HDF5:“/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000”://FAPAR_QF
SUBDATASET_2_DESC=[651x1701] //FAPAR_QF (8-bit character)
SUBDATASET_3_NAME=HDF5:“/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000”://FAPAR_err
SUBDATASET_3_DESC=[651x1701] //FAPAR_err (8-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
I get a list of all subsets. Apparentely there is no coordinate system right?
But if I make
gdalinfo HDF5:“/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000”://FAPAR (one of the SUBSETS) I get:
Driver: HDF5Image/HDF5 Dataset
Files: none associated
Size is 1701, 651
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0,
AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”,0.0174532925199433,
AUTHORITY[“EPSG”,“9108”]],
AXIS[“Lat”,NORTH],
AXIS[“Long”,EAST],
AUTHORITY[“EPSG”,“4326”]]
Corner Coordinates:
Lower Left ( 0.0, 651.0)
Upper Right ( 1701.0, 0.0)
Lower Right ( 1701.0, 651.0)
Center ( 850.5, 325.5)
Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT=product
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:SCALING_FACTOR=10000
FAPAR:OFFSET=0
FAPAR:MISSING_VALUE=-10
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
This means that it’s georreferenced right?
But if I do
r.in.gdal -o --quiet input=HDF5:“/mnt/GIS/ DATA /HDF5_DATA_MSG_FAPAR_Euro_200702220000”://FAPAR output=out00
I get the error:
Over-riding projection check
G_set_window(): Illegal latitude for NorthOver-riding projection check
So it doesn’t’ work. I mean shouldn’t I be using gdalwarp in order to import and rectify image? Because there is not much inofmration regarding how to do this. I mean, it seems that if I do r.in.gdal I loose all GCP and coordinates system information…
Sorry for these lammer questions but I think I’m lost
Thanks
Pedro
2010/2/17 Pedro Roma <pedroroma1982@gmail.com>
Thank you all.
Thanks
Best regards
Pedro
Hello Pedro
Antonio
http://www.eset.com
2010/2/17 Pedro Roma <pedroroma1982@gmail.com>:
Hello all
Size is 512, 512
Coordinate System is `'
Subdatasets:
SUBDATASET_1_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
SUBDATASET_2_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_QF
SUBDATASET_3_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_err
Corner Coordinates:
right?
But if I make
gdalinfo HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
Size is 1701, 651
GEOGCS["WGS 84",
DATUM\[&quot;WGS\_1984&quot;,
    SPHEROID\[&quot;WGS 84&quot;,6378137,298\.257223563,
        AUTHORITY\[&quot;EPSG&quot;,&quot;7030&quot;\]\],
    TOWGS84\[0,0,0,0,0,0,0\],
    AUTHORITY\[&quot;EPSG&quot;,&quot;6326&quot;\]\],
PRIMEM\[&quot;Greenwich&quot;,0,
    AUTHORITY\[&quot;EPSG&quot;,&quot;8901&quot;\]\],
UNIT\[&quot;degree&quot;,0\.0174532925199433,
    AUTHORITY\[&quot;EPSG&quot;,&quot;9108&quot;\]\],
AXIS\[&quot;Lat&quot;,NORTH\],
AXIS\[&quot;Long&quot;,EAST\],
AUTHORITY\[&quot;EPSG&quot;,&quot;4326&quot;\]\]
Corner Coordinates:
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT\_ID=0
FAPAR:N\_COLS=1701
FAPAR:N\_LINES=651
FAPAR:NB\_BYTES=2
FAPAR:SCALING\_FACTOR=10000
FAPAR:OFFSET=0
FAPAR:MISSING\_VALUE=\-10
FAPAR:UNITS=N/A
FAPAR:CAL\_SLOPE=1
FAPAR:CAL\_OFFSET=0
Not necessarily. It is also possible that GCPs are stored and gdalwarp
needs to be
used first to obtain a really geocoded file.
But if I do
r.in.gdal -o --quiet input=HDF5:"/mnt/GIS/ DATA
/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR output=out00
I get the error:
and rectify image?
Say, use gdalwarp to preprocess the data. Please try with one channel and
post what gdalinfo reports on the resulting file.
coordinates system information...
Sorry for these lammer questions but I think I'm lost
Thanks
Pedro
Thank you all.
Regarding Antonio's suggestion I will see if I can do that. It seems a
Thanks
Best regards
Pedro
Hello Pedro
Antonio
http://www.eset.com
grass-user mailing list
grass-user@lists.osgeo.org
Pedro, regarding MODIS tip, that someone gave you, please try Method 1 and see what happens. I think it will be enough. Please pay attention to HDF5 instead of HDF4.
Antonio
Hello all
Size is 512, 512
Subdatasets:
Corner Coordinates:
right?
But if I make
Size is 1701, 651
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AXIS["Lat",NORTH],
    AXIS["Long",EAST],
    AUTHORITY["EPSG","4326"]]
Corner Coordinates:
  Metadata:
    FAPAR:CLASS=Data
    FAPAR:PRODUCT_ID=0
    FAPAR:N_COLS=1701
    FAPAR:N_LINES=651
    FAPAR:NB_BYTES=2
    FAPAR:OFFSET=0
    FAPAR:UNITS=N/A
    FAPAR:CAL_SLOPE=1
    FAPAR:CAL_OFFSET=0
needs to be
But if I do
I get the error:
and rectify image?
Thanks
Pedro
Thank you all.
Thanks
Best regards
Pedro
Hello Pedro
Antonio
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4874 (20100217) __________
http://www.eset.com
http://www.eset.com
Hey
needs to be
Since GRASS documentation extensively preprocess to GEOTIFF, I will try that. Is it the best thing to do?
ok here it goes
By using
I get:
Size is 1701, 651
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
AXIS[“Lat”,NORTH],
AXIS[“Long”,EAST],
Corner Coordinates:
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:OFFSET=0
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
If I do :
gdalwarp HDF5:“/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000”://FAPAR /mnt/GIS/testing.tif
I get:
ERROR 1: Unable to compute a transformation between pixel/line
and georeferenced coordinates for HDF5:/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000://FAPAR.
There is no affine transformation and no GCPs.
Is this helpful to solve this question?
At MODIS Wiki (http://grass.osgeo.org/wiki/MODIS) Gdal Warp is not used. Instead, it’s create a intermediate file (TIF) using gdal_translate and only then is r.in.gdal is used.
Thank you Markus and Antonio and Hamish for your help
Thanks
Pedro
Thank you all.
Thanks
Best regards
Pedro
Hello Pedro
Antonio
http://www.eset.com
Pedro Roma wrote:
By usinggdalinfo
I get:Driver:
Files: none associatedSize is 1701,
651Coordinate System
is:GEOGCS["WGS 84",
DATUM["WGS_1984",
AXIS["Lat",NORTH],
    AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]Corner
Coordinates:Upper Left ( 0.0,
0.0)Lower Left ( 0.0,
651.0)Upper Right ( 1701.0, 0.0)
Lower Right ( 1701.0, 651.0)Center
( 850.5, 325.5)Band 1 Block=1701x1
Type=Int16,
ColorInterp=Undefined Metadata:
FAPAR:CLASS=Data
    FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:OFFSET=0
    FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
If I do :gdalwarp
HDF5:"/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000"://FAPAR
I get:ERROR 1: Unable to compute a
transformation between pixel/lineand
the above tells you that it is in lat/lon WGS84, but the image itself
is not georeferenced.
are there possibly additional data bands named "lat" and "long" or so?
do you know what the north/south/east/west & resolution should be?
maybe there is another HDF5 viewer (ISTR a java one from NASA?) which
will export the info if it is a gdal or libhdf problem which is stopping
you from seeing that information (if it is there at all)
question?At MODIS Wiki (http://grass.osgeo.org/wiki/MODIS)
Gdal Warp is not used. Instead, it's create a
gdalwarp is used if there is no north/south/east/west info beyond the
number of image pixels, but there are a series of GCPs listed.
Hamish
hello Hamish
With some support from Ricardo I realized that there are also 2 other HDF5 files, one with latitude of each pixel and the other with longitude. So, now I have a latitude dataset, a longitude and values. How can I “merge” this and import to GRASS (georreferenced and bla bla)? (THat I wasn’t expecting to have).
By the way, thanks about gdalwarp enlightment.
Pedro
On Thu, Feb 18, 2010 at 12:17 PM, Hamish <hamish_b@yahoo.com> wrote:
Pedro Roma wrote:
By usinggdalinfo
I get:Driver:
is:GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
AXIS[“Lat”,NORTH],
AXIS[“Long”,EAST],
AUTHORITY[“EPSG”,“4326”]]Corner
Type=Int16,
FAPAR:CLASS=Data
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:OFFSET=0
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
If I do :gdalwarp
are there possibly additional data bands named “lat” and “long” or so?
Hamish
Hey
needs to be
ok here it goes
By using
I get:
Size is 1701, 651
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
AXIS[“Lat”,NORTH],
AXIS[“Long”,EAST],
Corner Coordinates:
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:OFFSET=0
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
If I do :
I get:
Thanks
Pedro
Thank you all.
Thanks
Best regards
Pedro
Hello Pedro
Antonio
http://www.eset.com
On Tue, Feb 23, 2010 at 10:16 AM, Pedro Roma <pedroroma1982@gmail.com> wrote:
By using
I get:
Size is 1701, 651
GEOGCS["WGS 84",
DATUM["WGS_1984",
AXIS["Lat",NORTH],
AXIS["Long",EAST],
Corner Coordinates:
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:OFFSET=0
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
If I do :
gdalwarp
I get:
Since this is a GDAL problem, please ask on the GDAL list.
Did you try the MODIS Reprojection Tool? Does that fail as well?
