[GRASS-user] HDF5 library conflict between R 2.4 and GRASS 6.2:
Greetings:
When using R within GRASS6, and loading the rgdal library, I encounter an error
loading a specific version of the HDF5 library that does not occur when I perform
the same operation in R 'outside' of GRASS6:
Here is a record of the error on my ubuntu system:
---------- Start ---------
reeves@wallace:~$ grass2
Cleaning up temporary files.....
Starting GRASS ...
Welcome to GRASS 6.2.1 (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
GRASS 6.2.1 (spearfish60):~ > R
R version 2.4.1 (2006-12-18)
Copyright (C) 2006 The R Foundation for Statistical Computing
ISBN 3-900051-07-0
R is free software and comes with ABSOLUTELY NO WARRANTY.
You are welcome to redistribute it under certain conditions.
Type 'license()' or 'licence()' for dGRASS 6.2.1 (spearfish60):~ > R
ISBN 3-900051-07-0
Type 'license()' or 'licence()' for distribution details.
Natural language support but running in an English locale
R is a collaborative project with many contributors.
Type 'contributors()' for more information and
'citation()' on how to cite R or R packages in publications.
Type 'demo()' for some demos, 'help()' for on-line help, or
'help.start()' for an HTML browser interface to help.
Type 'q()' to quit R.
[Previously saved workspace restored]
> library("rgdal")
Loading required package: sp
Error in dyn.load(x, as.logical(local), as.logical(now)) :
       unable to load shared library '/usr/local/lib/R/site-library/rgdal/libs/rgdal.so':
libhdf5-1.6.4.so.0: cannot open shared object file: No such file or directory
Error: package/namespace load failed for 'rgdal'
> library("rgdal")
------------------------- Trying the same thing Outside of GRASS ------------------------------
reeves@wallace:/usr$ R
ISBN 3-900051-07-0
> library("rgdal")
Geospatial Data Abstraction Library extensions to R successfully loaded
---------- End ---------
Would anyone have any suggestions?
I tried to find the 'missing' hdf5 library: libhdf5-1.6.4.so.0: in the archives, to no avail.
Thanks, Rick Reeves
Rick Reeves
Scientific Programmer / Analyst
National Center for Ecological Analysis and Synthesis
UC Santa Barbara
reeves@nceas.ucsb.edu
www.nceas.ucsb.edu
805 892 2533
[starting R's rgral package from within GRASS fails, outside of GRASS
it's ok]
Rick Reeves wrote:
> library("rgdal")
directory
does ubuntu have an apt-file package? If it does, you can use that tool
to
find the missing package.
e.g. on Debian/Sarge:
$ apt-file search libhdf5- | grep so
libhdf5-doc: usr/share/doc/libhdf5-doc/html/Tutor/software.html
libhdf5-lam-1.6.2-0: usr/lib/libhdf5-1.6.2.so.0
libhdf5-lam-1.6.2-0: usr/lib/libhdf5-1.6.2.so.0.0.0
libhdf5-mpich-1.6.2-0: usr/lib/libhdf5-1.6.2.so.0
libhdf5-mpich-1.6.2-0: usr/lib/libhdf5-1.6.2.so.0.0.0
libhdf5-serial-1.6.2-0: usr/lib/libhdf5-1.6.2.so.0
libhdf5-serial-1.6.2-0: usr/lib/libhdf5-1.6.2.so.0.0.0
another way of searching: (requries more guessing)
$ apt-cache search libhdf5
libhdf5-doc - Hierarchical Data Format 5 (HDF5) - Documentation
libhdf5-lam-1.6.2-0 - Hierarchical Data Format 5 (HDF5) - runtime files - LAM version
libhdf5-lam-dev - Hierarchical Data Format 5 (HDF5) - development files - LAM version
libhdf5-mpich-1.6.2-0 - Hierarchical Data Format 5 (HDF5) - runtime files - MPICH version
libhdf5-mpich-dev - Hierarchical Data Format 5 (HDF5) - development files - MPICH version
libhdf5-serial-1.6.2-0 - Hierarchical Data Format 5 (HDF5) - runtime files - serial version
libhdf5-serial-dev - Hierarchical Data Format 5 (HDF5) - development files - serial version
mpb-mpi - MIT Photonic-Bands, parallel (mpich) version
libhdf5-serial-1.6.1-0 - Hierarchical Data Format 5 (HDF5) - runtime files - serial version
or is it already on your machine?
$ locate libhdf5- | grep so
if so, which package it came from:
$ dpkg -S /usr/lib/libhdf5-1.6.1.so.0.0.0
libhdf5-serial-1.6.1-0: /usr/lib/libhdf5-1.6.1.so.0.0.0
my (very rough) guess though is that CRAN (R) is providing a precompiled
binary, which was compiled on someone else's machine with libraries in
different places. perhaps you need to use the R package install method
with compiles the module locally after source download?
Hamish
