Hi
I taking the advice of messages surrounding darrel maddy's nviz problem (mine too), I decided to download the grass-6.0.2.tar.gz source file & compile it. After typing in CFLAGS=-g -Wall" ./configure as per the instructions I get a "couldn't find gdal-config" message. I have installed (and uninstalled and reinstalled)...
gdal-1.3.1-2.i386 and gdal-bin-1.3.1-2.i386.
When I do a "locate gdal" I get reference to a number of files in the following directories...
/usr/bin
/usr/lib ( including libgdal.so.1 and libgdal.so.1.9.0)
/usr/share/gdal
However, in no directory is there such a file called "gdal" as is suggested by the error message.
On and off over the last couple of years (for days and sometimes weeks at a time) I have been trying to get GRASS working. I even purchased a dedicated linux machine-GRASS following difficulties with cygwin-GRASS under windows. Still I could not get the full suite to work so I recently rebuilt my system using fedora core 5 in the hope that would work. Alas, more tears. I am at my witts end.
P L E A S E CAN SOMEONE HELP.
Thanks
Ian Allan
Ian Allan
Director Geocode Mapping and Analysis P/L
PO Box 2072
Edithvale VIC 3196 Ph: + 61 3 9773 1232 Fax: + 61 3 9773 1232
Mob: 0429 941 527
Email: iallan@geocode.com.au
Web: www.geocode.com.au
