I am looking for some advice on the best way to polygonise large raster layers into shapefile format
The context for this question is the need to creating a slope-class vector layer for land-use classification.
The following steps are what I am currently doing
import SRTM data for the area I am interested in and then run r.fillnulls to fill the gaps
run r.slope.aspect to generate a raster of slope (in percent)
run r.reclass to classify the slope classes into 0-10%, 11-20%, 21-30% … 81-90%, 90-100% 100+%
then run a r.neighbour with type=mode on a 3 by 3 window to smooth some of the salt and pepper effect away.
then run r.to vect with the area flag to create a vector representation of slope
This usually creates a vector with tens of thousands of polygons
Then I run a v.out.ogr to create a shapefile
The last step is when I run into problems with 50 000 or more polygons. The shapefile tends to be corrupted with empty values in the dbf for slope and doesn’t reflect the vector file in the grass format.
The current work around is export the slope raster file as a tiff file. Import into arcgis then convert to shapefile. This approach im not happy with!! So any solutions would be greatly appreciated.
.... 81-90%, 90-100% 100+%
the dbf fo slope and doesn't reflect the vector file in the grass
format.
I don't know about the v.out.ogr bug, but another trick instead of
r.neighbors would be "v.clean tool=rmarea" to remove areas with area
smaller than thresh=<>.
