Greetings
I’m starting to use Wx Georrectifier (Geometric Correction) and, in a couple of messages from a few weeks I saw that some help for Georrectifer was added to GRASS but I didn’t find anything. could anyone point me out? Im using WinGRASS 6.4.0 (stable).
Thaks
Kim
Kim Besson wrote:
Greetings
I'm starting to use Wx Georrectifier (Geometric Correction) and, in a couple
to GRASS but I didn't find anything. could anyone point me out? Im using
The help is part of the new Georectifier in wxGUI (File -> Manage
Ground Control Points) which is available only in 6.4.1 and above. The
latest 6.4 Windows installer is available here [1]
Markus M
[1] http://josef.fsv.cvut.cz/wingrass/grass64/
Hi Markus
Thanks. I do have a weekly snapshot 6.4.1 but I don’t have that yet. is it possible to integrate that part in a earlier version of 6.4.1?
Thanks
Kim
By the way, How can I check which release am I using and, what changes have occured since my release?
2010/11/2 Markus Metz <markus.metz.giswork@googlemail.com>
Kim Besson wrote:
Greetings
The help is part of the new Georectifier in wxGUI (File → Manage
Markus M
On Tue, Nov 2, 2010 at 10:31 AM, Kim Besson <kimbesson1981@gmail.com> wrote:
Hi Markus
Thanks. I do have a weekly snapshot 6.4.1 but I don't have that yet. is it
The easiest way really is to get an updated snapshot.
g.version -r prints the GIS library revision number and time (not
necessarily the latest change included in your version).
This you could see here:
https://trac.osgeo.org/grass/log/grass/branches/releasebranch_6_4/
but it may be quite a bit, the version you are using must be older
than 5 weeks (it's about 5 weeks ago that I added the new GCP Manager
to the wxGUI in 6.4)
Markus M
Kim Besson wrote:
> Greetings
> couple
> added
Markus M
