I have installed grass 7.0 and would like to add the module ps.output from http://trac.osgeo.org/grass/browser/grass-addons/ps/. Unfortunately, I have no idea how to do this and my wed-search did not help much.
I tried g.extension, but ps.output is not listed in the default repository.
On Thu, Nov 26, 2009 at 10:28 AM, Martin Album Ytre-Eide
<Martin.Album.Ytre-Eide@nrpa.no> wrote:
Hello all.
Please try again (but in GRASS 6), I have renamed the SVN directory
from ps/ to postscript/:
Hello again, and thanks. I have installed GRASS 6.5 and the add-on ps.output seems to download fine, but I get an compilation error I don't understand:
mkdir -p /usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/etc/paint/patterns/
/usr/bin/install -c -m 644 patterns/*.eps /usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/etc/paint/patterns/
/usr/bin/install: cannot stat `patterns/*.eps': No such file or directory
make: *** [patt] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
GRASS 6.5.svn (utm33):~/gis/stratos/prog >
Anyone who understands what goes wrong?
Martin
-----Opprinnelig melding-----
Fra: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] På vegne av Markus Neteler
Sendt: 26. november 2009 19:43
Til: Martin Album Ytre-Eide
Kopi: grass-user@lists.osgeo.org
Emne: Re: [GRASS-user] Help installing from http://trac.osgeo.org/grass/browser/grass-addons/
On Thu, Nov 26, 2009 at 10:28 AM, Martin Album Ytre-Eide <Martin.Album.Ytre-Eide@nrpa.no> wrote:
Hello all.
Please try again (but in GRASS 6), I have renamed the SVN directory from ps/ to postscript/:
On Thu, Feb 18, 2010 at 2:15 PM, Martin Album Ytre-Eide
(yes, the patterns/ directory has not yet been submitted to SVN.)
Jorge: please submit it to GRASS-Addons in
grass-addons/postscript/ps.output/
PS: Martin, for now comment the last line in the Makefile.
On Thu, Feb 18, 2010 at 2:52 PM, Markus Neteler <neteler@osgeo.org> wrote:
Jorge,
I have now found patterns in 6.4 and submitted them.
Now the module compiles.
The permission should be alright, but the catalog /usr/local/grass-6.5.svn/g.extension.12845 does not seem to exist.
Martin
________________________________________
Fra: neteler.osgeo@gmail.com [neteler.osgeo@gmail.com] på vegne av Markus Neteler [neteler@osgeo.org]
Sendt: 18. februar 2010 21:10
Til: Martin Album Ytre-Eide; E. Jorge Tizado
Jorge,
Please check the file permissions in
I suspect that it was installed with root permissions/sudo before and now you
try as normal user or so.
Thank you for responding.
You are right. I installed grass with sudo and now tried as a normal user. It seems now that the permission and owner should be right.
However, despite this, I have got a new error message today:
U ps.output
Checked out revision 41157.
Compiling ps.output...
/usr/local/grass-6.5.svn/include/Make/Module.make:25: warning: overriding commands for target `install'
/usr/local/grass-6.5.svn/include/Make/Rules.make:82: warning: ignoring old commands for target `install'
make: *** No rule to make target `default', needed by `first'. Stop.
Any ideas ?
Martin
Sendt: 19. februar 2010 16:10
On Fri, Feb 19, 2010 at 11:48 AM, Martin Album Ytre-Eide
Hello.
I updated my GRASS 6.5 and now I get a different error:
