I am new to GRASS and i am trying to load the DTED data map in my visual c++ application. Actually i am trying to load dt2 data directly in my visual c++ application, i do not want to run GRASS as separate process with my application, In GRASS source code i need to identify the classes used to load a DEM or DTED data so i can directly try those with my visual c++ application.
Anybody know the classes and header files used in GRASS to load the dted data
Grass do not load DTED directly. It uses GDAL to do that. Look into GDAL (www.gdal.org) source code to solve your problem
Jarek
Anand V pisze:
Hi Everybody,
I tried and i am not able to identify.
Please give ur suggestions and help me out
Thanks in advance
ANAND V
