[GRASS-user] Help needed with interactive selection of vectors
List:
I work for the US National Weather Service at the Ohio River Forecast Center. We generate, on a daily basis, a graphic that looks like this: http://www.erh.noaa.gov/er/ohrfc/fop.html
The linked graphic would be pretty trivial to create in GRASS using ps.map. However, during times where there is a reasonable risk for significant flooding, the map must be altered to designate the smaller subbasins (or areas) that are at risk and to annotate the period over which the threat exists. I'm sorry I can not link an example to show, since there is no current flooding in the US or risk thereof.
Currently, the process is carried out interactively using ArcGIS. I am trying to offer up an open source alternative with GRASS. I am sure a more sensible, non-interactive way of generating the map explicitly through a modeling approach would be best (and we do, of course, base designating the basins at risk on hydrologic modeling), but there is no *direct* link. Currently human interaction is used and some will insist on this.
So, I am left wondering how to best approach this is GRASS, namely, either:
(1) have the ability to manually select smaller subbasins and group them together to designate the area at risk, or
(2) hand draw/digitize the area
Any suggestions are appreciated!
Tom
Thomas E Adams
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
I was not able to fully understand Your needs. Please clarify following aspects:
1) How input data looks like;
2) What do You mean by "manually select smaller subbasins"?
3) And what is "*direct* link"? Uniq ID or model result parser?
I assume You have following workflow:
1) run some closed modeling program, that outputs some (ASCII?) results;
2) operator adds some colors to existing shapes based on 1st step output;
3) result is uploaded to server.
If I'm correct, You could create parser for 1st step result file,
upload parsed results to database (PostGIS with basins or dbf for
joining with GRASS vectors) and generate image with areas colored by
attribute in GRASS/MapServer/GMT/et.al.
Sorry, if I was thinking in other direction,
Maris.
2007/11/8, Thomas Adams <Thomas.Adams@noaa.gov>:
List:
on this.
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
grassuser mailing list
grassuser@grass.itc.it
Maris,
Sorry for not being clear. Basically now the mode of operation is:
(1) launch ArcGIS which has been customized somewhat to do the following (some background coverages appear automatically for reference, as the link shows)…
(2) the user manually digitizes polygonal areas corresponding to the areas of flood risk
(3) the polygons are annotated to show the period over which they are valid
(4) the custom control buttons allow the user to export the map and to have a text file created and have it ftp'ed to another location
Now, all of this is pretty much doable in GRASS, though the GUI is not as refined and some coding changes would be needed (I think) to 'duplicate' this process. I'm trying to avoid this right now for several reasons, including time constraints. What I thought *could* be done, would be to have some reference subbasin boundaries displayed in the GRASS display window along with the other reference vector maps (state political boundaries and our area of responsibility). Allow the user to interactively select the basins at risk and have those areas ONLY display as areas of risk. Then the process would be similar to (1)—(4), except that:
(1) I do not see how polygons can be manually selected and have the option to remove unselected basins/polygons and
(2) I do not see how to manually annotate a polygon in such a way that the polygon(s) are clearly tied to the annotation.
However, this may all be moot because, it seems, a significant number of people want to have the ability to freehand draw the areas of risk, so that the selection process I was suggesting is not of interest.
Thanks you for your interest!
Tom
----- Original Message -----
Date: Thursday, November 8, 2007 2:46 pm
Subject: Re: [GRASS-user] Help needed with interactive selection of vectors
following aspects:
results;2) operator adds some colors to existing shapes based on
1st step output;
Maris.
> List:
Forecast> Center. We generate, on a daily basis, a graphic that
looks like this:
smaller> subbasins (or areas) that are at risk and to annotate the
period over
show,> since there is no current flooding in the US or risk thereof.
I am
sure a
base> designating the basins at risk on hydrologic modeling), but
there is no
insist> on this.
namely, either:
group them
> Regards,
> Tom
> Thomas E Adams
> VOICE: 937-383-0528
> FAX: 937-383-0033
> looks like this:
the site seems unreachable today for me.. endless wait.
> period over
it is simple to script ps.map with variable text & queries.
see example script below.
> am sure a
Human interaction is fine, at times of public risk human oversight is critical.
Automation is a great help though, and if the digitizing work can be 95%
prepared for the operator - and they just have to touch it up - then all the
better for speed of deployment & reduction of opportunities for human error.
> namely, either:
see script below for generating map simply from specified catchment IDs.
Digitize areas with v.digit over backdrop image. Backdrop image can be
static or with raster overlay from hydrologic model output.
(or digitize with QGIS, or digitizing frontend like OpenLayers WPS- try the
polygon tool: http://www.les-ejk.cz/english/pywps-and-openlayers )
shows)...
flood risk
this seems highly inefficient to me.
process.
It seems best done from a script, in which case the GUI is moot and the CLI is
king. If partial interaction is required, the script could be written to pop up
the digitizing tool as needed, then preview, "Accept or Re-edit", and finally
continue the script to do the rest.
A g.parser script could be made friendly & have checkboxes (e.g. the v.clean
GUI tool selection) to activate catchment by names/ID. Or a fancy front end
could allow the user to click on an area of a map. (e.g. parse 'd.what.vect
-xft'; or generate from the HTMLMAP monitor driver [see d.mon]; or pyWPS style
solution)
hopefully the model output will tell you (ie the script) which subbasins are at
risk...
limit by known catchment ID (vector feature category) or SQL query on vector
area attribute (catchment's name). Make the query part of the script set by a
environment variable, see example below.
In ps.map there is the vlegend instruction which does this automatically.
d.legend will display raster category labels, if present, and hide cat numbers.
Again, preparing a proto-map for the human digitizer to finish/check may be of
great value, both by speeding their workflow and reducing chances for error.
Manual-override at key steps would be very important of course.
Here is a little demo ps.map script I've thrown together demonstrating the
idea.
It builds on the Spearfish catchments generated in the (brand new) r.watershed
help page example*. All you need to specify is catchments at risk, it does the
rest.
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/raster/r.watershed/front/description.html?rev=HEAD&content-type=text/html
screenshots of output for whole catchment warning and lowlying areas warning:
  http://bambi.otago.ac.nz/hamish/grass/screenshots/flood_warning_basins.png
  http://bambi.otago.ac.nz/hamish/grass/screenshots/flood_warning_lowlying.png
screenshot of Spearfish catchments:
  http://grass.itc.it/screenshots/raster.php
First we need to generate polygons for low lying ares from each catchment
created with the r.watershed help page example:
# create danger polygons for each catchment
# (homebrew example of predictor for at-risk lowlying areas)
r.cost -k in=slope out=slope_cost_from_rivers start_rast=rwater.course
r.colors slope_cost_from_rivers col=bcyr -e
# choose some threshold. this could be based on hydrologic model output.
# for now just set for lower half of slope-costs in the map
eval `r.univar -g slope_cost_from_rivers`
r.mapcalc "flood.zones = if(slope_cost_from_rivers < $mean, \
     rwater.basin, null() )"
# convert to vector areas
r.to.vect -s in=flood.zones out=flood_zones feature=area
v.db.dropcol map=flood_zones column=label
v.db.renamecol map=flood_zones column=value,catchment
# dynamic bits, set by model or interactive selection
# (eg scripted 'd.what.* -xft' to highlight areas)
# Here we say catchment #6 and #12 are at risk.
FLOOD_BASINS=6,12
TIMESTAMP=`date`
# the rest is a static template
# commands could be written to a file and then passed to ps.map input=
# convert catchment list to SQL query
FLOOD_BASIN_SQL=`echo $FLOOD_BASINS | \
  sed -e 's/^/catchment = /' -e 's/,/ OR catchment = /g'`
# generate PostScript image
ps.map out=flood_warning.ps << EOF
raster elevation.dem
# example of dashed lines
vlines roads
  style 000011
  where label ~ 'highway'
  width 0.25
  label Highways
  end
vlines rwater_course
  color grey
  label Water courses
  end
vareas rwater_basins
#change to "flood_zones" vector map for lowlying areas instead of
# entire catchment
  where $FLOOD_BASIN_SQL
  color red
  fcolor red
  width 2
  pat $GISBASE/etc/paint/patterns/diag_up.eps
  label Catchements subject to flood risk
  end
vlegend
  end
text 100% -3% Warning issued $TIMESTAMP
  font Helvetica-BoldOblique
  fontsize 12
  ref right
  end
end
EOF
# convert to PDF
ps2pdf flood_warning.ps
# convert to PNG
pstoimg -antialias -aaliastext -out flood_warning.png -scale 1.3 \
  -crop tb flood_warning.ps
The PDF output looks the best.
Rendering problems:
* EPS hatch pattern renders in gv and PNG with black boxes behind lines??
    These do not appear in PDF + acrobat reader.
* EPS hatch patterns are tiled so fill lines have slightly noticeable breaks.
* We need to add something to allow skipping vectors in ps.map's vlegends
    ideas: labelskip [y|N], test for label='' or 'none' or 'skip'?
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
