[GRASS-user] help needed with polar projections
Hello:
I am new Grass user, and am having some problems trying to set up a
polar projection. I am using Grass 6.0.2 that I compiled, and am
working on a RedHat Linux system.
I have tried to set up a Universal Polar Stereographic (UPS) projection,
as well as an Antarctic Polar Stereographic projection. The UPS
projection did not appear to work at all. The Antartic Polar
Stereographic projection didn't fail, but when I reproject a vector file
with Antarctica, the results are not what I expected. I think that I
may have set the default region incorrectly, because only a small
portion of Antarctica appears in the monitor. The details of the
projections and region follow below.
Any suggestions for how to set up a UPS projection or other polar
projections, or how to define the region setting properly for the
Antarctic polar projection would be much appreciated!
Many thanks,
Dan Gillespie
Here are the projection parameters for the 2 locations:
UPS
  GRASS 6.0.2 (SouthPole2):~ > g.proj -w
  WARNING: OGR can't parse PROJ.4-style parameter string:
           +proj=ups +south +a=6378137 +rf=298.257223563 +no_defs
            +towgs84=0.000,0.000,0.000 +to_meter=1.0000000000
            (OGR Error code was 5)
  WARNING: g.proj: Unable to convert to WKT
  GRASS 6.0.2 (SouthPole4):~ > g.proj -w
  PROJCS["Stereographic",
         GEOGCS["wgs84",
              DATUM["unknown",
                  SPHEROID["wgs84",6378137,298.257223563]],
              PRIMEM["Greenwich",0],
              UNIT["degree",0.0174532925199433]],
      PROJECTION["Polar_Stereographic"],
      PARAMETER["latitude_of_origin",-71],
      PARAMETER["central_meridian",70],
      PARAMETER["scale_factor",1],
      PARAMETER["false_easting",0],
      PARAMETER["false_northing",0],
      UNIT["meters",1]]
  Here is the default region for this location:
  N: 0
  S: -90
  W: -180
  E: 180
  grid resolution NS: 1
      EW: 1
  rows: 90
  columns: 360
Hi Daniel!
You have specified your region in longitude/latitude while you work in
Polar Stereographic Projection whose coordinate system has "meters" as
unit. You have to convert your lat/long values first, and don't
forget to set the resolution to a proper value!
Henning
On Thu, 11 Jan 2007 13:24:24 -0500, Daniel.Gillespie wrote:
Hello:
Many thanks,
Dan Gillespie
UPS
         GEOGCS["wgs84",
              DATUM["unknown",
      UNIT["meters",1]]
  N: 0
  S: -90
  W: -180
  E: 180
      EW: 1
  rows: 90
  columns: 360
grassuser mailing list
grassuser@grass.itc.it
Henning,
Please note Daniel is reprojecting a vector, so region settings don't
matter.
Daniel,
Please use a newer version. The latest stable is 6.2.1 and it is highly
recommended over 6.02.
The region (both input and output) is not taken into account when
reprojecting vectors. It matters only when reprojecting rasters (r.proj).
UPS
Based on EPSG code 32761 [1], that should rather be:
+proj=stere +lat_0=-90 +lat_ts=-90 +lon_0=0 +k=0.994 +x_0=2000000
+y_0=2000000 +ellps=WGS84 +datum=WGS84 +units=m
To update your projection settings use g.proj -c in the PERMANENT
mapset of your location, or edit the PROJ_INFO manually.
         GEOGCS["wgs84",
              DATUM["unknown",
      UNIT["meters",1]]
This seems OK, but please note the last line should be:
UNIT["metre",1]]
instead. I recall it is a bug fixed after 6.02. At least it is in my
6.3 CVS.
Maciek
[1] I'm guessing by the output of this command:
$ grep UPS -A1 /usr/local/share/proj/epsg
# WGS 84 / UPS North
<32661> +proj=stere +lat_0=90 +lat_ts=90 +lon_0=0 +k=0.994 +x_0=2000000
+y_0=2000000 +ellps=WGS84 +datum=WGS84 +units=m +no_defs <>
# WGS 84 / UPS South
<32761> +proj=stere +lat_0=-90 +lat_ts=-90 +lon_0=0 +k=0.994
+x_0=2000000 +y_0=2000000 +ellps=WGS84 +datum=WGS84 +units=m +no_defs <>
Your epsg file might be located elsewhere, depending on where you have
PROJ.4 installed.
