[GRASS-user] Help regarding v.isochrones using spgrass7
I installed the v.isochrones add-on in GRASS7 but it didn’t build a .exe in the bin directory in installation folder, but i am able to use it using the GRASS console.
Now if i try to use the v.isochrones from R using spgrass7 package and execGRASS() it says v.isochrones.exe not found.
How can i use the add-on v.isochrones from within R?
I think if I get a v.isochrones.exe in the bin folder it would work with R.
Thanks in advance.
Sent from Windows Mail
yogesh bansal wrote
I installed the v.isochrones add-on in GRASS7 but it didn't build a .exe
the GRASS console.
R.
Thanks in advance.
v.isochrones is a python script (see [1]), and not an exe-binary.
I assume you're using winGRASS.(?)
addons are stored in
C:\Users\YourWindowsUsername\AppData\Roaming\GRASS7\addons: binaries are
stored in the bin-subfolder, scripts (v.isochrones.py) are stored
script-subfolder.
in winGRASS wrapper-bat-files (e.g. v.isochrones.bat) are stored in the
bin-subfolder.
not tested, adding
C:\Users\YourWindowsUsername\AppData\Roaming\GRASS7\addons to your %PATH%
may help.
[1]
http://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.isochrones/v.isochrones.py
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-regarding-v-isochrones-using-spgrass7-tp5193391p5193394.html
