I need to do the following:
Display a sewer network and generate charts with classification in a colour scale based on attributes like Age, Material, Diameter, etc.
Data are in a MySQL database:
The network is geometrically defined by the relationship between these two tables:
tbl_line:
“LINE_ID”,“FROM_NODE_ID”,“TO_NODE_ID”
1,1,2
tbl_node
“NODE_ID”,“X_COORDINATE”,“Y_COORDINATE”,“Z_COORDINATE”,“NET_TYPE_ID”
1,3400630.04,5718486.603,1,
Assuming that attributes where also stored in the same table: tbl_line, which is not the case, how would be the better way to perform this task? Attributes are actually stored in another table, tbl_basedata, which is in the same database and has a 1:c relationship to tbl_line.
So far I have managed to connect to the MySQL-database but cannot figure out how to further proceed.
Previously I had tried following workaround:
1.I performed a MySQL-query on tbl_node and tbl_line to obtain the couples of points defining a line and stored this in a .csv-file.
2. From this I created a new file with an awk-programm like this:
#‘X_COORDINATE, Y_COORDINATE’
L 2 0
3400630.04 5718486.603
3400639.238 5718515.776
L 2 0
3400648.641 5718546.057
L 2 0
3400665.041 5718562.99
L 2 0
3400625.996 5718597.349
L 2 0
3.I successfully imported this with v.in.ascii and can depict the geometry.
But I don’t think that is the most logical way to do it as GRASS can connect directly to the DB. Any suggestions???
Thanks in advance
– Jorge Echeverri SP |
