[GRASS-user] Help using color tables (differences)
List:
I have been using r.colors -n map=mapname color=differences to display soil moisture differences from one day to another (to identify areas that have received precipitation and areas that are drying); I would like to depict wetting areas as shades of blue to white and drying areas as shades of white to red — as the the option color=differences tries to do. The difficulty I'm running into is that unless there is a fairly even proportion of of positive & negative values I'll have wetting areas colored a shade of red instead of blue, but more often, the reverse where drying areas are colored blue, due to the shift of the color scale. Ideally, I want values close to -0- to be white and wet areas to be a shade of blue and dry areas to be a shade of red. How can I do this? Any suggestions?
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
Hi Thomas,
try the 'r.colors.stdev -z' which was recently moved into the
main source tree from the addons repository. maybe a new option
could be added to do a better differences map.
some examples here:
  http://hamish.bowman.googlepages.com/grass_color_maps
for the color rules $GISBASE/etc/differences does:
0% blue
0 white
100% red
what you really want is to have it evenly scaled like:
peak = the greater of abs($min) and abs($max)
-$peak blue
0 white
$peak red
you could use awk to do that a>b logic in a script if you needed
to.
then use those rules as custom color rules with r.colors.
or for you entire dataset decide some static rules, then inter-
map differences are comparable on the same visual scale.
Hamish
Hamish,
Thank you! I think your suggestion will work for me; I'll let you know…
Cheers!
Tom
----- Original Message -----
Date: Friday, August 7, 2009 6:39 pm
Subject: Re: [GRASS-user] Help using color tables (differences)
Hi Thomas,
some examples here:
0% blue
0 white
100% red
-$peak blue
0 white
$peak red
to.
Hamish
Hamish,
I just tried using r.colors.stdev -z — I guess I incorrectly *assumed* it would not do what I wanted. It looks like it does what I want except for the option to invert the colors. So, adding the 'Invert' option would be great.
Tom
Hi Thomas,
some examples here:
0% blue
0 white
100% red
-$peak blue
0 white
$peak red
to.
Hamish
On Sat, 2009-08-08 at 15:35 -0400, Thomas.Adams@noaa.gov wrote:
Hamish,
Tom
Perhaps a (very) stupid (attempt to) work-around for the time being:
"r.colors -n rast=..." on a map already colored based on "r.colors.stdev
-z" :-?
Nikos
> Hi Thomas,
> some examples here:
> 0% blue
> 0 white
> 100% red
> -$peak blue
> 0 white
> $peak red
> to.
> Hamish
grass-user mailing list
grass-user@lists.osgeo.org
if you don't mind such things it's trivial to open the script up
in a text editor and add the -n flag, or change red<->blue.
on "r.colors.stdev -z" :-?
in fact very smart -- it works well:
#spearfish
g.region rast=elevation.dem
eval `r.univar -g elevation.dem`
r.mapcalc "elev.diff = elevation.dem - $mean"
r.colors.stddev -z elev.diff
d.mon x0
d.rast elev.diff
# flip current color rules:
r.colors -n elev.diff rast=elev.diff
d.rast elev.diff
Hamish
