Hi list. I have recently started to use the grass software. And now im stuck in a batch file.
I installed the grass software using the .deb package grass_6.0.2-6_i386.deb. Also installed the gdal libraries. And the programs works fine with the spearfish database and the console.
Now, I tried to run a shell script but doesn’t work. The only thing that I want to have is the version of the GRASS program in a file.
I have unpacked the spearfish database in /var/www/grass/DATAGRASS
And my batchfile looks like this
/var/www/grass/var.sh
GISBASE=/usr/lib/grass
GISDBASE=/var/www/grass/GRASSDATA
GISRC=/var/www/grass/.grassrc6
LOCATION_NAME=spearfish60
MAPSET=rsiis
LOCATION=/var/www/grass/GRASSDATA/spearfish60/rsiis
PATH=$PATH:/usr/lib/grass/bin:/usr/lib/grass/scripts
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/grass/lib
HOME=/var/www/grass/
GIS_LOCK=$$
rm -f version_info.*
rm -f grasserrors.*
g.version >> /var/www/grass/version_info.txt 2>> /var/www/grass/grasserrors.txt
the .grassrc6 looks like this
GISBASE: /usr/lib/grass
GISDBASE: /var/www/grass/GRASSDATA
LOCATION_NAME: spearfish60
MAPSET: rsiis
DIGITIZER: none
HOME: /var/www/grass/
Well, when I executed the
#./var.sh
I got this response
./var.sh: line 14: 16732 Segmentation fault g.version >>/var/www/grass/version_info.txt 2>>/var/www/grass/grasserrors.txt
The number after de “line 14” changes every time that I run the shell.
What am I doing wrong? Can you help me?
Thanks in advance.
Humano
http://jiuman.blogspot.com
