[GRASS-user] help with batch exporting r.out.gdal
Dear All,
I just created a list of files (NPPFILES) using g,mlist command in grass7.
Now I would like to export these files as .tiff files.
I tried this command
for files in $NPPFILES; do
r.out.gdal input=“$NPPFILES” output=“$NPPFILES.tiff” format=GTiff ; done
This is not working for me. I tried giving directory path, still no result.
I will be grateful if anybody can help me with this.
Thanking you,
Regards
Rajat Nayak
Rajat,
I assume you are running this at the GRASS prompt? If not, you must do this. Also, if you don’t provide the full path for ‘NPPFILES’, you should run the command from the directory where ‘NPPFILES’ is located. Additionally, you may want to change your code to this:
for files in $(cat NPPFILES); do
echo $files;
You may want to include the line “echo $files;” to see if the individual map names are being read correctly
Tom
On Tue, Sep 2, 2014 at 8:57 AM, Rajat Nayak <rajat27404@gmail.com> wrote:
Dear All,
Thanking you,
Regards
Rajat Nayak
grass-user mailing list
grass-user@lists.osgeo.org
Thank you Tom for the mail.
I’m still unable to get it working. Some smaller cliche I guess,
will try again.
Regards
Rajat Nayak
On Tue, Sep 2, 2014 at 6:50 PM, Thomas Adams <tea3rd@gmail.com> wrote:
Rajat,
echo $files;
Tom
Dear All,
Thanking you,
Regards
Rajat Nayak
>> grass7. Now I would like to export these files as .tiff files.
>> r.out.gdal input="$NPPFILES" output="$NPPFILES.tiff" format=GTiff ; done
Here, you ask the string "files" to get each of the whatsoever values
are stored inside the variable $NPPFILES.
1. is there an NPPFILES variable defined already? Something like
NPPFILES="
file_1
file_2
flie_3"
2. What you actually need to feed the "input=" parameter, is the "files"
term, not the "$NPPFILES".
>> result.
ok, assuming you are running this from inside a GRASSy session, you
should be, at the time of executing the for loop, inside the directory
where the "list of files" is also present. I guess you created a file,
say "nppfiles_list".
To be sure, just instruct
cat nppfiles_list
and expect to get the list of files you created.
If that's ok, then it should work, e.g.:
for File in `cat nppfiles_list`; do r.out.gdal input=${File}
output=${File}.tiff; done
Note, instead of "File" it could be any other string you like.
Hope this helps a bit.
Nikos
Thank you Nikos and Tom.
The command worked.
This is what I used,
for files in cat NPPFILES; do r.out.gdal in=“${files}” out=“${files}” format=“GTiff”; done
Regards
Rajat Nayak
On Thu, Sep 4, 2014 at 12:39 PM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
Here, you ask the string “files” to get each of the whatsoever values
NPPFILES="
file_1
file_2
flie_3"
  1. What you actually need to feed the “input=” parameter, is the “files”
    term, not the “$NPPFILES”.
result.
where the “list of files” is also present. I guess you created a file,
say “nppfiles_list”.
cat nppfiles_list
If that’s ok, then it should work, e.g.:
for File in cat nppfiles_list; do r.out.gdal input=${File}
Note, instead of “File” it could be any other string you like.
Nikos
