[GRASS-user] Help with creating bathymetric maps
..... and since you are in the maritimes you might be interested to see
what Bob Covill is doing with GRASS and other open source tools:
http://www.tekmap.ns.ca/
really a mix of GRASS, Postgis (for really massive datasets), GDAL tools,
and GMT are all very useful if each is used to its strength.
I must say though, GRASS's r.contour does a really brilliant job if the
input raster map is of good quality.
Hamish
Hello again,
This is all great info and I am sure the links will be helpful. Also the
heads up on several issues are of great value. I haven't given up yet but
find myself occasionally stubbing over unfamiliar terms such as a quadtree
(but I will look it up). I do have the last GRASS book but can't claim to
understand too much even though I have all three editions. The arrival of
QGIS has helped a lot as well as the associated tutorials. Getting my data
in is no longer a problem (projections) as well as simple manipulations. I
currently have installed GRASS 6.4, QGIS (Kore 1.0) and find FWtools
helpful. I have also found the book Desktop GIS to be useful.
If I can sort all of this out I may following your suggestion of put
together a tutorial, however, I feel someone more knowledgeable would have
to review it. There might be aspects I have overlooked or better ways of
accomplishing the same thing.
I will do my homework and might be back with a few more questions. By the
way I think v.extract will get me my shoreline boundaries as points and then
I can merge the two vector files (shoreline and depths), then do the raster
conversion.
Thanks for the help.
Alyre
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/Help-with-creating-bathymetric-maps-tp2896653p2948118.html
