Good morning all,
I’m looking for some help with NVIZ which keeps dropping out on my Ubuntu Hardy / GRASS 6.4 set up when loading a raster with the following message -
“Error in startup script: Togl: X server has no OpenGL GLX extension
while executing
“togl $Nv_(TOP).canvas -rgba true -double true -depth true”
(procedure “Nv_makeGUI” line 56)
invoked from within
“Nv_makeGUI $Nv_(AREA)”
(file “/usr/lib/grass64/etc/nviz2.2/scripts/nviz2.2_script” line 1052)”
Any suggestions welcome!
Kind regards
Rebecca
Rebecca Bennett wrote:
I'm looking for some help with NVIZ which keeps
"Error in startup script:
What it says: your X server doesn't support OpenGL. You should ask on
an Ubuntu forum for advice on fixing this.
Great thanks for the heads up Glenn
To: Rebecca Bennett rabennett@ymail.com
Cc: grass-user@lists.osgeo.org
Sent: Fri, 4 June, 2010 10:47:52
Subject: Re: [GRASS-user] Help with NVIZ crash
What it says: your X server doesn’t support OpenGL. You should ask on
