Hola Leo!
Hello community!
I would like to ask a little help for a brand new 7 GRASS module: r.hants.
In this module there are some option that can be chosen. One of them is:fet=float - Fit error tolerance
Anyway in the manual there is no explanation about how to use this option,
that actually seems to be quite useful.
I would like to know how to use it. Should this error tolerance be
indicated as a percentage?
There’s no specific explanation for that parameter, you are right… But there’s the reference paper at the bottom of the manual page where you can find some more help
Roerink, G. J., Menenti, M. and Verhoef, W., 2000. Reconstructing cloudfree NDVI composites using Fourier analysis of time series. International Journal of Remote Sensing, 21 (9), 1911-1917. DOI:10.1080/014311600209814
Anyway, as far as I understand this “fet” parameter is relative to the variable you are working with, in terms of the values of the variable how much error would you admit in the reconstruction. For example, in ndvi, I guess it should be in the order of 0.1.
In my case, to set values of different parameters (as there’s no a fixed rule and is more a kind of try and error thing), I changed one parameter at a time, letting the rest with a fixed value… So, I could see the effect of changing each parameter.
Hope this helps a bit!
Vero
