[GRASS-user] help with r.series
Dear All,
I have created a few list using g.mlist command in grass7. Each list has a few raster layers. For example; FILE2000 has lists of all monthly layers for the year 2000, FILE2001 has layers for 2001…so on.
Now I want to create one layer each for each of these lists (each year). I can use “r.series” command with method=“average”, to get a layer with averaged values across all the months for a particular year. Now I have 14 such lists corresponding to 14 years and do not want to repeat the process for each year. Is there a way to automate this process using grass prompt? I don’t want to move to R, would like to complete all the work in GRASS.
Thank you
Regards
Rajat Nayak
Hi Rajat,
the year 2000, FILE2001 has layers for 2001...so on.
can use "r.series" command with method="average", to get a layer with
don't want to move to R, would like to complete all the work in GRASS.
Yes you can do it, using BASH or python, personally I prefer/use python.
A possible solution for grass6/7 could be something like:
from grass import script
# define the pattern to select the maps that will be aggregate
PATTERNS = ('rast2001*', 'rast2002*', 'rast2003*') # etc.
# define the name of the output names
OUTPUTS = ('out2001', 'out2002', 'out2003')
# start a cycle for each pattern and for each output
for pattern, output in zip(PATTERNS, OUTPUTS):
    # get the list of input maps
    inputs = script.mlist_strings('rast', pattern=pattern)
    # run your command
    script.run_command('r.series', input=inputs, output=output,
method='average')
for the year 2000, FILE2001 has layers for 2001...so on.
I don't want to move to R, would like to complete all the work in GRASS.
bash:
  for file in FILE20?? ; do
      r.series file=$file output=output${file#file} method=average
  done
Python:
  import os
  import grass.script as grass
  for file in os.listdir('.'):
      if not file.startswith('FILE20'):
          continue
      output = 'output' + file[4:]
      grass.run_command('r.series', file=file, output=output,
                        method='average')
