first of all, sorry about my english, and about this message. I hope this
was the correct place. I'm trying to vectorize the areas from a image map,
and I'm a rookie with GRASS. If anyone could help me a little, it would be
great.
An example of the map i'm trying to vectorize is this:
http://n2.nabble.com/file/n3274836/recorte.jpg
I've tried using r.mapcalc, r.color, and other to preprocess the map befor
using r.to.vect and i can't get the areas (not the green, the others). I
don't know how to do it.
Again, sorry if this isn't the place.
Andres
View this message in context: http://n2.nabble.com/Help-with-r.to.vect-tp3274836p3274836.html
incanus wrote:
...I'm trying to vectorize the areas from a image map,
great.
Hi Andres!
Did you specify the "feature=area" parameter? E.g.:
r.to.vect in=RasterMap out=VectorMap feature=area
Also, check the manual of r.to.vect [1].
Kind regards, Nikos
[1] http://grass.osgeo.org/grass64/manuals/html64_user/r.to.vect.html
or just type "r.to.vect help" in the command line.
Maybe it would be useful (for others) to keep posts "on" the list as
well.
Cheers, Nikos
On Mon, 2009-07-20 at 12:08 +0200, andresfr wrote:
I've already get it. I've used:
r.mapcalc
paso1=b#original
end
r.colors map=paso1 color=rules
0 white
234 white
235 black
end
r.neighbors input=paso1 output=paso2 method=minimum size=3
r.null map=paso2 setnull=0-234
r.to.vect input=paso2 output=paso3 feature=area
and that's what finally worked for me.
great! Thanks for the feedback.
Nikos
here it is,
Andres
View this message in context: http://n2.nabble.com/Help-with-r.to.vect-tp3274836p3288090.html
