I'm trying to update an attribute table column using v.db.update with
the DBF driver and keep getting a dbmi: Protocol error message.
Example using Spearfish
g.copy vect=fields,myfields
v.db.addcol myfields col="polynum integer"
v.db.select myfields where="label like 'V%'"
cat|label|polynum
59|V. White#1|
v.db.update myfields col=polynum val=42 where="label like 'V%'"
ERROR: Error while executing: 'UPDATE myfields SET polynum=42 WHERE
label like V%
I've tried this on both winGrass 6.4 rc2 or winGrass 6.5 r45847 on
winXP using the wxGUI via both the v.db.update module and the wxgui
command line and get the same error issue.
"I don't know" is the short answer. Hamish's suggested worked here for v.db.update, but when I used "like" in v.db.update, it failed with the same error as you saw.
Perhaps a bug in the driver?
Richard
On 6/04/11 5:12 PM, Sharon M wrote:
Why does the DBF driver handle like when using v.db.select?
On Wed, Apr 6, 2011 at 4:29 PM, Richard Chirgwin
cat|label|polynum
59|V. White#1|
label like V%
Richard - are you working in a win XP environment? If so which vers of WinGrass?
Sharon
On Wed, Apr 6, 2011 at 4:48 PM, Richard Chirgwin
error as you saw.
Richard
cat|label|polynum
59|V. White#1|
label like V%
No - Mac. So perhaps Win interprets the delimiters differently?
Richard
Sharon
error as you saw.
Richard
cat|label|polynum
59|V. White#1|
label like V%
