All:
Below is the detailed output I’m getting from running r.inund.fluv on Ubuntu 13.10, GRASS 6.4.3.
My DTM is 30m x 30m (the best I can do at the moment) and distances between cross-sections is on the order of 300-500 meters – could this explain my results (no maps are created)?
Tom
(attachments)
grass_cmd_output.txt (11.5 KB)
Tom,
On Sat, Apr 19, 2014 at 9:23 PM, Thomas Adams <tea3rd@gmail.com> wrote:
All:
Below is the detailed output I'm getting from running r.inund.fluv on Ubuntu
13.10, GRASS 6.4.3.
cross-sections is on the order of 300-500 meters -- could this explain my
Could you please provide an example based on the North Carolina
dataset? Then it is easier to reproduce.
Markus,
I don’t think I can do this because it would require setting up a hydrodnamic unsteady flow model for a stream in the NC data set and preparing the necessary input file for r.inund.fluv once I had successfully run the model. I can not see in the NC data set that any of this is available and I am just not in a position to undertake the effort. What is missing is a georeferenced channel centerline with the associated modeled water surface elevation profile.
Thank you for your help.
Tom
On Sat, Apr 19, 2014 at 3:42 PM, Markus Neteler <neteler@osgeo.org> wrote:
Tom,
All:
13.10, GRASS 6.4.3.
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
On Sat, Apr 19, 2014 at 10:42 PM, Thomas Adams <tea3rd@gmail.com> wrote:
Markus,
I don't think I can do this because it would require setting up a
Yes, ok. Then I see two options
- shell debugging with -x option, see
http://grasswiki.osgeo.org/wiki/GRASS_Debugging#Shell_script_debugging
- try to contact the authors of r.inund.fluv who will know it better
than most of us.
best
Markus,
Thank you for the suggestion; attached is the detail using the -x option.
Cheers!
Tom
(attachments)
r.inund.fluv_grass_cmd_output.txt (22 KB)
Markus,
best
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
