[GRASS-user] hexagon rasters
Hello List,
I'm interested in working with hexagonal rasters. I know I can make hexagon vectors with "v.mkgrid -h", but is there any way to then work with these in raster space? I'd like to use r.walk and r.cost to estimate costs to move around the hex grid.
  -k.
Hi Ken,
On Tue, Feb 8, 2022 at 4:44 AM Ken Mankoff <mankoff@gmail.com> wrote:
Hello List,
I am sure you considered v.to.rast?
# North Carolina sample dataset
g.region raster=elevation res=5000 -pa
# create vector hexagons
v.mkgrid map=hexagons -h
v.info -c hexagons
# convert to raster model, requires the resolution to be increased
(example: 5000m -> 250m)
g.region res=250 -p
v.to.rast input=hexagons output=hexagons use=cat
# viz
d.rast hexagons
d.vect hexagons type=boundary
Now you may turn them into cost surfaces.
Best,
Hi Markus,
Yes - that works but requires downstream hacks because of the different resolutions. Still, it is a workable solution I didn't think of. Thank you!
  -k.
On 2022-02-09 at 12:52 -08, Markus Neteler <neteler@osgeo.org> wrote:
Hi Ken,
Hello List,
v.info -c hexagons
g.region res=250 -p
# viz
d.rast hexagons
Best,
Hi Ken,
On Thu, Feb 10, 2022 at 1:16 AM Ken Mankoff <mankoff@gmail.com> wrote:
Hi Markus,
Of course those could be scripted as well using eval():
eval `g.region -g`
# or:
# eval $(g.region -g)
echo $n $w $e $s
HTH,
