Thank you for your reply.
And your quoted research paper(by Dr.Tatem,etc.) is very informative on me.
I can find "Superresolution Mapping Using a Hopfield Neural Network
With Fused Images" by Minh Q. Nguyen, Peter M. Atkinson, and Hugh G. Lewis,
IEEE Transaction on Geoscience and Remote Sensing, vol.44, No.3, pp736-749
(2006).
But I have never done neural network analysis on remote sensing visible
band data. And I can find the function or tool of neural network analysis
only in the ENVI/IDL software package in my laboratory.
And I cannot find any tool or module on neural network analysis
in the GRASS software.
I will introduce some research paper for solving mixel problem as follows.
1. Yoshiki Yamagata and Yoshifumi Yasuoka (1996) “Unmixing wetland vegetation types by subspace method using hyperspectral CASI image”, Int. Archives of Photogrammetry and remote
Sensing, 31(7), pp.781-787
2. The VSW index method and its algorism by Yoshiki Yamagata, et al
The Journal of the Remote Sensing Society of Japan (in Japanese), 17(4), pp.54-64(1997)
3. David A. Landgrebe (2003) "Signal Theory Methods in Multispectral Remote Sensing",
Wiley Series in Remote Sensing book ISBN 0-471-42028-X
There is some explanations for the hyper spectral remote sensing data analysis,
such as the Spectral Angle Mapper(SAM). And this book is the manual of "MultiSpec",
a kind of open source software.
https://engineering.purdue.edu/~biehl/MultiSpec/
When I sent my e-mail to the Purdue university developing team, Dr. David A.
Landgrebe, professor emeritus of Purdue university, directly replied to my question.
Thank you.
(2012/05/15 17:20), Luigi Ponti wrote:
Dear 山田 康晴,
Thanks for your kind reply.
On 15/05/2012 03:18, 山田 康晴 wrote:
I wonder why you want to use the Landsat TM data for the analysis of
the high resolusion agricultural land cover.
The reason is that I found that paper I cited in my previous email
(Tatem et al. 2003;
<http://eprints.soton.ac.uk/260104/1/tatem_tgis.pdf>\), which described a
way to increase resolution of land cover. I thought higher resolution
would be a good thing because of the highly fragmented agricultural
landscape I was targeting (the paper by Tatem and colleagues also
analyzes an area with small-scale agriculture in Greece).
The Landsat TM, not ETM, has very long histry and is not the High-resolution
data as for both spatial and frequential points of view.
There are so many research papers for the analysis on agricultural
land cover.
I have accessed the grass-user mailing list seeking for a possible
GRASS-based approach to the task. Hence, I would be very glad if you
could point to a couple of the research papers you refer to.
The "esa" or Italy scientists must have much information for your interest.
Are you a scientist in Italy?
Yes, I am based in Italy and my background is mostly in applied ecology.
Of course people at ESA are expert in the field. My goal when accessing
this mailing list was to see if more GRASS-related info on the topic
would emerge that may benefit me and other GRASS users.
Kind regards and thank you,
Luigi
We are targeting an agricultural area in southern Italy (several
thousands hectares) for which we have full orthophoto coverage (0.5
meters resolution), and Landsat TM data can apparently be downloaded
freely from<http://glcf.umd.edu/data/landsat/>\. High-resolution
agricultural land cover might seem overkill, but the area is highly
fragmented and hence standard CORINE land cover data tend to classify
most of the land as mixed types (not very helpful).
I would like to ask a general recommendation on the best way to approach
an agricultural land cover task such as the one outlined above, together
with possible info on previous implementation of increasing spatial
resolution of agricultural land cover maps in GRASS via neural networks
or other approaches.
Kind regards, thanks in advance and apologies for a long post,
Luigi
grass-user@lists.osgeo.org
Yasuharu Yamada
Chief Researcher,
Research Project for Resources Information Technology,
NIRE, NARO Japan
yamaday@affrc.go.jp
http://nkk.naro.affrc.go.jp/
This e-mail is intended only for the designated recipient(s) and may
contain confidential information. Please don't forward the message
to the other person(s) or place(s) without prior notice.
