Thank you for your hints, however I didn't managed to solve the problem.
I installed NetPBM tools has you suggested, however I still get hundreds
of .ppm files instead of one big high resolution file like I need.
the programs need to be in the system search %PATH% so that GRASS can
find them.
I then tried Windows command prompt with these sentences:
C:\Program Files (x86)\GnuWin32\bin>pnmcat -lr C:\Users\Andre\Pictures\aaa\E-W-45_1_1.ppm
C:\Program Files (x86)\GnuWin32\bin>pnmcat -tb C:\Users\Andre\Pictures\aaa\E-W-45_1_1.ppm
In both cases all I get has output can be seen in attachment, but no
assembled image is produced. What am I doing wrong?
unfortunately the help page doesn't note that it sends the image to
stdout. what you're seeing is what you'd see if you tried to open the
image in a text editor.
Thank you for your hints, however I didn’t managed to solve the problem.
find them.
unfortunately the help page doesn’t note that it sends the image to
stdout. what you’re seeing is what you’d see if you tried to open the
