Dear GRASS GIS user,
I am using r.resamp.rst to interpolate climatic data at 30sec resolution over Africa.
Grass script, data, and results are available here:
https://nextcloud.fraisedesbois.net/index.php/s/CKzsZCSCqMTY9rq
# Import Africa shapefile
v.in.ogr --overwrite input=gisdata/vectors/Africa layer=Africa output=Africa
# Rasterize Africa at 30 arc-sec resolution
g.region -ap vector=Africa res=0:00:30
v.to.rast input=Africa type=area output=Africa use=val value=1
# Import climate
r.in.gdal --overwrite input=gisdata/rasters/test1.1_044.tif output=test1_1
# Resample with RST
g.region -ap raster=test1_1
# Note: use maskmap=Africa to save computation time
r.resamp.rst --overwrite input=test1_1 elevation=test1_1_rst \\
ew_res=0.00833 ns_res=0.00833 maskmap=Africa
r.info test1_1_rst
# Resample to exact resolution 0:00:30
g.region -ap res=0:00:30
r.resample --overwrite input=test1_1_rst output=test1_1_30s
# Export
r.out.gdal --overwrite input=test1_1_30s \\
output=output/test1_1_30s.tif type=Float32 \\
createopt='compress=lzw,predictor=2'
When I use r.info on the interpolated raster, it indicates a tension of 7278 in the comments which seems very high to me as the default value is 40.
| Comments:
| tension=7278.552524
| dnorm=5.495598, zmult=1.000000
| KMAX=50, KMIN=35, errtotal=0.000535
| zmin_data=0.056488, zmax_data=3.756866
| zmin_int=-0.066779, zmax_int=3.214336
On the other side, results do not look so bad (see test.pdf figure).
Would you have any comment on this high value for the tension and do you think interpolation has been performed correctly ?
Best regards,
Ghislain
_______________________________________________________
Ghislain VIEILLEDENT
CIRAD - UMR AMAP
botAnique et Modélisation de l'Architecture des Plantes et des végétations
TA A51/PS2
F-34398 Montpellier cedex 05
FRANCE
Phone: +33.6.24.62.65.07
Skype: ghislain.vieilledent
E-mail : ghislain.vieilledent@cirad.fr
Research unit web site: http://amap.cirad.fr
Personal web site: https://ecology.ghislainv.fr
BioSceneMada project: https://bioscenemada.cirad.fr
