Doc Robinson <doc.robinson@utoronto.ca> writes:
hi again,
Hi
I forward this to the grass-user list as these are relevant questions.
I am gearing up to install homebrew then the various versions of GRASS.
I have already installed XQuartz, but I noticed that on one page with
instructions they list it as being installed after homebrew...does it
matter?
I can't think of any reason why it should matter.
On the Apple app store the version of Xcode is 7.1 while the example on
http://coolestguidesontheplanet.com/installing-homebrew-os-x-yosemite-10-10-package-manager-unix-apps/is 6.3 is home brew sensitive to the version?
In general, you should always use the newest version of Xcode - I never
had problems with this and
--8<---------------cut here---------------start------------->8---
brew doctor
--8<---------------cut here---------------end--------------->8---
even warns you if a newer version is available.
no rush...thanks in advance
No problem.
Just be aware that the grass recipe from homebrew does not work at the
moment, but the osgeo4mac recipes[1] grass-64 is working, grass-70
produces errors but I guess you can install it with --without-gui.
There is also my port of the osgeo recipe for 7.0 to install 7.1 (-HEAD
only) at https://github.com/rkrug/homebrew-head-only, which presumably
has the same problems as grass-70
Rainer
On 2015-10-07 12:09 PM, Rainer M Krug wrote:
Envoyé de mon iPhone
Le 7 oct. 2015 à 17:56, Doc Robinson <doc.robinson@utoronto.ca> a
écrit :Hi I saw your post on the GRASS list about using homebrew to
install both 7.0 and 7.1 under both Yosemite and El Capitan.I have just taken delivery of macmini with Yosemite on it. I do not
intend to upgrad to El Capitan unless there is an absolute need for
me to.Unless you have a really good reason, I would upgrade to El Capitan.
Most of the problems occur in upgrades - not new installations.My question is related to homebrew and installing GRASS 6.4.x. Have
you done that or have you just done the 7.x installs on your
system?I have 6.4 installed as well.
It will be my first try at using homebrew.
In my opinion (with my Linux background) homebrew plays an important
in the Apple universe. I try to install everything using homebrew and
if makes many things much easier for me.But one thing I learned: try to avoid mixing homebrew with the
standard apple packages- this can cause difficult to identify
problems.Don't hesitate to come back with further questions. Possibly cc the
grass user mailinglist as this might be if general interest.Cheers,
Rainer
thanks in advance.
-- Regards, Doc
Vincent B. Robinson |
Department of Geography | E-Mail: doc.robinson@utoronto.ca
University of Toronto | Voice: (905)828-5299 at Mississauga
| Fax: (905)828-5273 Mississauga, Ontario | Canada L5L
1C6 |
Footnotes:
[1] https://github.com/OSGeo/homebrew-osgeo4mac
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
