[GRASS-user] How can I place multiple ps.map maps in one graphic?
List,
I see from the documentation that ps.map allows only one raster map per run of ps.map. But what if I want to show a panel of say, 4 different maps (each with it's own raster map) in one graphic — for comparison purposes. Could I, for instance, generate 4 eps files from ps.map and have ps.map lay them out?
thanks,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
Thomas,
Yes your approach is correct; get ps.map to compose the eps files, then insert each eps into your master output file.
~ Eric.
-----Original Message-----
From: grassuser-bounces@grass.itc.it on behalf of Thomas Adams
Sent: Wed 10/24/2007 2:56 PM
To: GRASS user list
Subject: [GRASS-user] How can I place multiple ps.map maps in one graphic?
List,
maps (each with it's own raster map) in one graphic - for comparison
thanks,
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
grassuser mailing list
grassuser@grass.itc.it
I have created a new wiki page explaining the trick.
   http://grass.gdf-hannover.de/wiki/Ps.map_scripts
Also of note, I have added to the wiki:
- Willem's instructions for making the Norway geology screenshot.
   http://grass.gdf-hannover.de/wiki/Psmap_moldefjord_example
- New links to GFOSS.it's north arrows, meteorology, geology, and trees symbol
  sets. Also added are instructions on how to use inkscape from the command
  line to convert SVG to EPS (for use with ps.map).
   http://grass.gdf-hannover.de/wiki/IconSymbols#Other_contributions
Still needed: someone to write a little script to convert EPS images into
GRASS's display symbol format. It would be nice if the same converter could
create d.graph drawing commands as well (this part is probably pretty easy).
i.e., it would be good to be able to display EPS in an xmon and create symbols
in ways other than by hand.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
