[GRASS-user] How merge several raster float and monoband
I have several raster float64 and monoband partially overlapping to each other.
My need is to merge each other to obtain 1 only larger raster.
Actually I do this using the gdal_merge utility, but in my global
process I will prefer to do this merge in the grass environment.
I know the r.composite command , but AFAIK it is only to compose a
raster RGB from three gray monoband raster and fully overlapping.
Thx.
Andrea Peri
qwerty àèìòù
Hi Andrea,
you may try " r.patch ".
Il 26/07/2015 13.09, Andrea Peri ha scritto:
Thx.
Thx Roy,
I will try it.
2015-07-27 10:10 GMT+02:00 Roy <royroge@outlook.com>:
Hi Andrea,
other.
Thx.
grass-user mailing list
grass-user@lists.osgeo.org
Andrea Peri
qwerty àèìòù
