I created the vector file (lines) with r.to.vect
In help I red that NO CATEGORIES for lines are created (I understood - the obiect hasn't identifier). I need to work on data base with them so I need give them a cat values
The manual entry is not an option because there is over 32000 lines
any ideas?
I can't still use PostGIS due to problems with installation (if somebody will sugest it)
Jarek
Jarek Jasiewicz napisa³(a):
any ideas?
Jarek
grassuser mailing list
grassuser@grass.itc.it
I solved it using v.category.
Sorry for fuss
Jarek
