After I’ve got my v.net.distance up and running I have to adjust my analysis method to the software’s capabilities. Basically, I have a 3 layered network: myroads_net2 which contain layers as follow:
As one might understood I’m trying to calculate the lowest cost route between each settlement (layer 3) to each landfill (layer 2). Roads’ costs are constant, which now set to 1 (currency per distance unit - I guess that it is meter). I would like to include a cost for landfill (gate fee) which will be measured with the same currency. MY attempt to use ncolumn (cost for nodes) didn’t go well. I have opened a new column (double precision) in layer 2 and named it gatefee. I have assigned 0 to all cats, except cat=3 which I have assigned with 60. My expectation was that at least some of the settlements that were allocated to cat=3 on layer 2 will be allocated to another one. However after running v.net.distance again with ncolumn=gatefee I have found out that more settlements were allocated to cat=3 of layer 2.
Did I misused that option? I can’t find any guide to how to use it in the manual or tutorials and will appreciate an explanation or a reference to such guide or tutorial.
On Thu, Mar 28, 2013 at 2:52 PM, דור פרידמן <dof1985@gmail.com> wrote:
Hello all,
After I've got my v.net.distance up and running I have to adjust my analysis
method to the software's capabilities. Basically, I have a 3 layered
As one might understood I'm trying to calculate the lowest cost route
I think v.net.distance is the wrong module for this task because it
finds for each 'from' feature the nearest 'to' feature and not the
shortest path from each 'from' feature to each 'to' feature. Actually,
I don't think any of the v.net.* modules does exactly that. You could
file a ticket for enhancement to request such a module.
Roads' costs
nodes) didn't go well. I have opened a new column (double precision) in
If I understand the code of v.net.distance correctly, node costs are ignored.
Markus M
Did I misused that option? I can't find any guide to how to use it in the
Hello all,
You can use v.net.allpairs, but you would have to put all points into the same layer. (Actually if you use grass 6.4 arcs and points will have to be in the same layer. I would recommend using grass7 for these tasks).
In GRASS7, just put all points into nlayer=2 with different cat values (example have all the landfills be in the 10000s and all the settlements in the 20000s - you can use v.category for that). Then run v.net.allpairs and filter out only the results showing the distance between a landfill and a settlement.
I was very surprised to read your comment about v.net.distance since the manual indicates the following:
“v.net.distance - Computes shortest distance via the network between the given sets of features.
Finds the shortest paths from each ‘from’ point to the nearest ‘to’ feature and various information about this relation are uploaded to the attribute table”
Is it possible that you had a mistake, or is it that the manual is incorrect?
Is the manual is correct? How can I assign costs to the destination nodes to receive the “lowest cost” (shortest) path from each origin node to the nearest (cheapest) target node?
Hello all,
finds for each ‘from’ feature the nearest ‘to’ feature and not the
shortest path from each ‘from’ feature to each ‘to’ feature. Actually,
I don’t think any of the v.net.* modules does exactly that. You could
Roads’ costs
Markus M
On Mon, Apr 1, 2013 at 10:23 AM, דור פרידמן <dof1985@gmail.com> wrote:
Hi Markus,
From the manual:
…the table has three columns: cat, tcat and dist storing category of each from feature, category of the nearest to feature and the distance between them respectively.
No contradiction AFAICT.
That does not make sense because destination nodes are usually not crossed. Assigning costs to nodes makes more sense for nodes between the start and the end node.
The shortest path for each ‘from’ node to the nearest ‘to’ node is included in the output map. See also the example in the manual.
Hello all,
Roads’ costs
Markus M
It might be valuable to add an option to assign costs to the destination nodes, either for my purpose when there is an actual gate fee that influence the total cost (e.g. waste management, national parks and reserves) or when the “gate fee” or nodes cost represent other factors that influence an individual decisions, i.e. external costs that describe socio-environmental parameters, such as: level of crime, general maintenance, scenery, number of shops in a commercial center, hospitals reliability and quality etc.
I will appreciate if you could direct me to the place I can ask for an improvement of the v.net.distance tool.
Regarding to the current analysis, I have though of two solutions and would like to get your (and all others) idea about it:
Follow Markus’s original suggestion to perform the analysis using v.net.allpairs - which will be easy to the empirical anlysis using excel, but more complex to create a map for the final shortest distance.
Try to assign costs to the nodes that connect each arc (formed by v.net) to the original network. My fear is that instead of assign cost just to the path to the destination node, it will also include those who attempt to use the original network to arrive to another destination. I’m also not sure about how to locate the nodes I’m looking for.
Hi Markus,
From the manual:
Hello all,
Roads’ costs
Markus M
reserves) or when the "gate fee" or nodes cost represent other factors
1. Follow Markus's original suggestion to perform the analysis using
v.net.allpairs produces a vector map of all shortest paths. You just have to extract those you need.
v.net.allpairs
That was Moritz.
the original network to arrive to another destination. I'm also not sure
about how to locate the nodes I'm looking for.
In this case, don't assign costs to nodes. The attribute table of the
output of v.net.distance includes the category of the nearest 'to'
node. You can then add a new column to the table and add node costs to
the reported distance for each 'to' node separately.
Node costs are only considered when a node is crossed, not when a node
is reached: pass through the gate vs. arrive at the gate. I understand
that you would like to give different preferences to destination nodes
which is a different problem and would require an additional option to
the module.
First of all, v.net.distance needs to be updated to consider node
costs in general, and also to consider backward travelling costs for
arcs. This applies also to some other of the new v.net.* modules.
Markus M
Any advice?
Thanks
Dor
2013/4/1 Markus Metz <markus.metz.giswork@gmail.com>
> Hi Markus,
>> "v.net.distance - Computes shortest distance via the network between
>> Finds the shortest paths from each 'from' point to the nearest 'to'
>> attribute table"
> incorrect?
From the manual:
...the table has three columns: cat, tcat and dist storing category of
> to receive the "lowest cost" (shortest) path from each origin node to
The shortest path for each 'from' node to the nearest 'to' node is
Markus M
> Best,
> Dor
> 2013/3/29 Markus Metz <markus.metz.giswork@gmail.com>
>> > Hello all,
>> > analysis
>> > Layer 1: Arch (roads)
>> > Layer 2: Points (Landfills - destinations)
>> > Layer 3: Points (Settlements - source)
>> > Roads' costs
>> > guess that
>> > which
>> > (cost for
>> > in
>> > cat=3
>> > of the
>> > to
>> > ncolumn=gatefee
>> > layer 2.
>> ignored.
>> Markus M
>> > the
>> > to
>> > Best,
>> > Dor
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user@lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
