hello
I have DEM of some part of mountains chain and i would like to calculate a real area of this (area in 3d not plane area).
I wonder if Grass can do it.
best
maciej
hello
best
maciej
hello
best
maciej
Just to clarify, you mean surface area as opposed to footprint of the
mountain range. So the sum of all the surfaces of the 3d model?
Alex
The solution to that problem would be r.surf.area which should give you
both the 2D and 3D area.
You'll have to actually try this as I just read about it in Markus and
Helena's book.
to my mind, one has to be cautious with this module, and be aware of how
surfaces are estimated. It appears that results show a big variability
given the current region resolution.
(just try r.surf.area on a sloppy plane [generated with r.plane],
knowing its inclination and thus its actual surface in advance)
Bye,
Vincent
Le mardi 16 septembre 2008 à 02:28 -0700, Alex Mandel a écrit :
Alex Mandel wrote:
> Maciej Tomaszczyk wrote:
>> hello
>> best
>> maciej
>> Maciej Tomaszczyk
>> Polish Geological Institute
>> Geological Mapping Department
>> http://www.pgi.gov.pl
>> http://www.opengeology.pl
> Alex
Helena's book.
