On 08/02/07 00:19, Hamish wrote:
Moritz Lennert wrote:
Yes, try "v.clean tool=snap". Or before reprojection "v.clean
tool=break".
'break' on the source map does not find any intersections to break.
'snap' on target map (v.clean in=nuts2 out=nuts2_snap_0_001 tool=snap thresh=0.001 - which if I calculated correctly should snap anything within a bit more than 100 meters) gives me an even worse result (even
less areas are recognized):
try making snap very small in the lat/lon location. The default is
intended to be 1mm, not 1degX10-3. so try 1e-8.
tried this, but it makes it worse (thresh=0.000000001):
http://moritz.homelinux.org/grass/target_snap_0_000000001.jpg
Based on your other
screenshots what about enlarging the snap thresh to 0.1 or so (in the
source loc'n) to get those lines to connect before reprojection?
http://moritz.homelinux.org/grass/source_snap_0_1.jpg.jpg
I take
it the same lines do not connect with d.vect+d.zoom?
That is another issue I have: trying to zoom in either in the GIS Manager or with d.vect+d.zoom I get CPU overheating (never had that before) and memory errors when I get to around 1e-8.
It is very odd.
Yes. I don't understand the lose edges without nodes...
Actually the original files were shapefiles, and so I finally did the reprojection with the shpproj tool from shapelib. I can then import the resulting file into a lat-long GRASS location and there are no problems.
Exploring this a bit further: I just tried duplicating the cleaning done by v.in.ogr by launching:
v.clean in=inmap out=outmap_clean_vinogr tool=snap,bpol,rmdupl,break,rmdupl,rmsa,chdangle,rmdangle,chbridge,rmbridge thresh=0.000001
And, behold !, I get a perfect map. So, now I have to isolate which of the cleaning tools did the job.
Moritz
