[GRASS-user] How to copy vector columns between databases
I have a vector layer FOO which is linked to two tables in layers 1 and 2.
The categories for each vector element are different in layer 1 and (e.g. a certain area may have the cat value "51" in layer 1 and a cat value of "42" in layer 2).
Let's assume that layer one has a VARCHAR column containing the names of the region (e.g. database_layer_1: 51,"Wolfenstein" database_layer_2: 42 )
If a new VARCHAR column is added to layer 2 by v.db.adcol,
how can the the names from layer 1 be copied into it?
[Goal: database_layer_1: 51,"Wolfenstein" database_layer_2: 42,"Wolfenstein" ]
Unfortunately, v.db.update seems only to work within one layer.
An UPDATE/SELECT SQL-statement will not be possible unless a table can be produced which holds the categories for both database layers for each geometry element.
How can this be solved ?
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
Sensationsangebot nur bis 30.11: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
On 25/11/08 16:29, peter.loewe@gmx.de wrote:
At this stage, the only way I can see to solve this problem is using v.build option=cdump. This gives you something like this:
---------- CATEGORY INDEX DUMP: Number of layers: 2 ---------------------------- ----------
Layer 1 number of unique cats: 6 number of cats: 6 number of types: 1
             type | count
                1 | 6
  category | type | line/area
         1 | 1 | 1
         2 | 1 | 2
         3 | 1 | 3
         4 | 1 | 4
         5 | 1 | 5
         6 | 1 | 6
Layer 2 number of unique cats: 6 number of cats: 6 number of types: 1
             type | count
                1 | 6
         1 | 1 | 1
         3 | 1 | 2
         5 | 1 | 3
         7 | 1 | 4
         9 | 1 | 5
        11 | 1 | 6
So, you see that the line/area id can be used to find the correspondance between the category values in both layers (i.e. in this case cat 3 in layer 1 is the same object as cat 5 in layer 2.
Unfortunately, there is no script friendly output from v.build (ToDo...), but still it should be possible to wrap this into a script with some python or awk magic. The easiest would probably be to use a real SQL backend (i.e. not dbf) and to add a column with the line id to each feature (i.e. 'v.db.update col=lineid value=$line where="cat=$cat"' where $line and $cat are the variables of the script read from the v.build ouput...
If you come up with a script, I think that this would be very useful. One thing I have been confronted with before was the desire to create a second layer with exactly the same category values (which didn't start at 1 and which had no regular step as they were statistical id codes of municipalities) which currently isn't possible.
But adding a clayer option to v.db.update might be another solution.
Moritz
Moritz,
thanks for your response. I didn't think of the option to use v.build yet and will try to set up an awk-script eventually.
That's where I also started...
Peter
-------- Original-Nachricht --------
Datum: Wed, 26 Nov 2008 14:34:17 +0100
Von: Moritz Lennert <mlennert@club.worldonline.be>
An: peter.loewe@gmx.de
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] How to copy vector columns between databases
> Hi,
2.
"42" in layer 2).
42,"Wolfenstein" ]
geometry element.
number of types: 1
             type | count
                1 | 6
         1 | 1 | 1
         2 | 1 | 2
         3 | 1 | 3
         4 | 1 | 4
         5 | 1 | 5
         6 | 1 | 6
number of types: 1
             type | count
                1 | 6
         1 | 1 | 1
         3 | 1 | 2
         5 | 1 | 3
         7 | 1 | 4
         9 | 1 | 5
        11 | 1 | 6
v.build ouput...
Moritz
Dr. Peter Löwe
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
On Tue, Nov 25, 2008 at 4:29 PM, <peter.loewe@gmx.de> wrote:
g.copy vect=roads,myroads --o
v.info -c myroads
v.db.addtable myroads table=extratab layer=2 columns="cat
integer,label varchar(100)"
v.db.select myroads layer=2
cat|label
-> Uffa: this should be set!! Bug in v.to.db :frowning:
... ok, I have made some fixes in SVN (r34494 and r34495) but they don't
seem to be sufficient. See related mail on grass-dev.
Now you need a join operation (db.execute). Note that this isn't
supported with DBF driver:
# I use SQLIte here:
v.db.connect -p myroads
Vector map <myroads@sqlite> is connected by:
layer <1> table <myroads> in database
</home/neteler/grassdata/spearfish60/sqlite/sqlite.db> through driver
<sqlite> with key <cat>
layer <2> table <extratab> in database
# bug workaround:
db.droptable extratab -f
db.copy from_table=myroads to_table=extratab
cat|label
0|no data
1|interstate
2|primary highway, hard surface
3|secondary highway, hard surface
4|light-duty road, improved surface
5|unimproved road
# simulate almost empty table (note that I fixed v.db.dropcol right
now for layer=2):
v.db.dropcol myroads layer=2 column=label
v.info -c myroads layer=2
# add new column with desired name:
v.db.addcol myroads layer=2 col="names varchar(100)"
Displaying column types/names for database connection of layer 2:
INTEGER|cat
CHARACTER|names
cat|names
0|
1|
2|
3|
4|
5|
# now JOIN the names into:
echo "UPDATE extratab SET names=(SELECT label FROM myroads WHERE
extratab.cat=myroads.cat);" | db.execute
# voilà:
cat|names
0|no data
1|interstate
5|unimproved road
Nice exercise :slight_smile:
TODO: fix v.to.db for layer>1.
v.info -c myroads
cat|label
IIUC, the result is actually correct since myroads does not contain any categories in layer 2 (see my response on grass-dev).
But you got us on the right track: there actually is a way to copy cats of one layer to another layer (e.g. here from layer 1 to layer 2):
v.db.addcol FOO layer=2 col='cat1 int'
v.to.db FOO layer=2 col=cat1 option=query qlayer=1 qcol=cat
Only if any of the two layers do not have a table attached do you need the v.db.addtable above, and to make that work you actually need categories in both layers (which isn't the case in Markus' example)...
# bug workaround:
cat|label
0|no data
1|interstate
5|unimproved road
This "works" because v.db.select selects all tuples in the table irrespective of whether these tuples have any corresponding features in the layer.
now for layer=2):
INTEGER|cat
CHARACTER|names
cat|names
0|
1|
2|
3|
4|
5|
# voilà:
cat|names
0|no data
1|interstate
5|unimproved road
Try clicking on any of the roads : do you actually see these results in layer 2 ?
It works AFAIU, you just need to use the query option.
Moritz
(back from grass-dev)
On Thu, Nov 27, 2008 at 10:06 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
And to respond to Peter's original query, i.e:
"42" in layer 2).
it should actually be (assuming that the varchar attribute in layer 1 is
called 'name':
v.db.addcol FOO layer=2 col='name varchar(Size)'
v.to.db myroads layer=2 option=query col=name qlayer=1 qcolumn=name
Now a FAQ:
http://grass.osgeo.org/wiki/Vector_map_attribute_transfer_between_connected_tables
Excellent. Thank you Markus!
Another proof how the community benefits when simple minds address stuff they can't figure out by themselves,
Simple minded,
Peter
Datum: Thu, 27 Nov 2008 11:39:14 +0100
Von: "Markus Neteler" <neteler@osgeo.org>
CC: "GRASS user list" <grass-user@lists.osgeo.org>
2.
(e.g.
of
>> "42" in layer 2).
of
42 )
> called 'name':
Now a FAQ:
Dr. Peter Löwe
