[GRASS-user] how to create a Finite Element mesh from XY data?
hi all,
I need to re-create a finite element mesh from XY data, (from input files for a groundwater model someone else built in a different platform (IWFM). Would appreciate some help in figuring out how to take the 2 files below, and create a polygon vector layer with element ID assigned to polygons.
The nodes and elements are in 2 files, here is what they look like:
  1. nodes file has node id, x,y (utm 10 wgs 84 i think), and a region id
C Groundwater Node Locations
C The following lists the node number and x & y coordinate of each node
C
C ID; Groundwater node number
C X,Y; Coordinates of groundwater node location; [L]
C
C-------------------------------------------------------------------------------
C Node ----------Coordinates----------
C ID X Y
1 563734 4308465
2 565407 4308558
3 566687 4308507
4 567636 4308465
  1. element files links the nodes to element ids
File Description
C
C This file contains the element configuration for each element.
C The nodes that make a finite element are listed for each element in
C a counter-clock wise fashion starting with any node. For triangular elements,
C the fourth node is specified as zero.
C
C
C For example,
C
C 13-------------14----------17
C I I I
C I 2 I 3 I
C I I I
C I I I
C 15------------- 16
C
C
C The configuration for elements 2 and 3 will be listed as,
C
C element node 1 node 2 node 3 node 4
C 2 13 15 16 14
C 3 14 16 17 0
C Element ------------Corresponding Nodes------------------ Subregion
C IE IDE(1) IDE(2) IDE(3) IDE(4) IRGE
1 1 5 6 2 1
2 3 2 6 7 1
3 3 7 8 4 1
4 11 6 5 10 1
5 11 12 7 6 1
6 12 16 8 7 1
7 13 9 17 0 1
Thanks for any help!
Vishal
Vishal K. Mehta, PhD
Sr. Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
