Dear All,
I hope I am not repeating something already been answered.
Environment: I have grass621 on a redhat linux.
I have two questions:
Q1. I want to create a location and a mapset via a shell script. I can
create it by invoking grass in a text mode (or gui interface mode) and
then stepping through several screeens (location , mapset input in the
1st screen, projection in the next screen, bounding box for the region
in the 3rd screen and so on). I am wondering whether it is possible to
do all in a script by invoking a set of commands. If so what should be
the sequence of commands.
Q2: Once I create a location and mapset I want to import a vactor map
expoted from MapInfo as .MIF and .MID files. Here we can use v.in.ogr.
But will it have any issues with region deifnition? DO I have to
explicitly specify region before importing MapInfo data?
Thanks in advance,
-Karun
Hi!
I don't think setting a region before importing vector data is required
except if you would like to limit import of some data to a specific
region of your interest and use for this purpose the "-r" flag of
v.in.ogr
Thanks in advance,
-Karun
Regards, Nikos
Use g.proj or g.mapset with the -c flag (note that the version of
g.mapset in 6.2.x doesn't have the -c flag; that requires 6.3.0).
If you want to do this from outside of GRASS, you can start GRASS
non-interactively by running the grass62 script with the full path to
an existing mapset directory as an argument.
