[GRASS-user] how to create multiband/hyperspectral
Hello!
I give up - cannot find the solution. :slight_smile:
I've created a python script to automatically process ASTER CD-s and create all the raster layers in grass from a given CD automatically. Now I have a LOT of raster layers.
*** I would like to join raster layers covering the same area *** to make only one file for one area. So, how to make a multispectral file using several raster layers? I have 3-14 bands I'd like to join per image
How to make it?
I checked grass documentation, commands, but simply cannot figure how to make it.
I realized that there is an i.group command - that could be fine for rasters as well...
Maybe the answer is too simmple, that's why I can't find.
Thanks for any help
Robert
Robert,
It isn't clear what you want to do. If you want to patch together adjacent
images (i.e., rasters covering different geographic areas), use r.patch.
If you want to make a color image out of 3 bands, use d.rgb to just display
a color image, or r.composite to combine 3 bands into a new color image
file.
GRASS stores all individual 'bands' as separate rasters that you can
combine, analyze, and process in multiple ways. It does not combine multiple
bands into a single 'file'.
Some processes can deal with a group of images/bands covering the same
geographic area as a 'group'. A group is created with i.group. But a 'group'
is simply a reference to a set of images; it does not combine them into a
single multi-band file. This is unnecessary with GRASS.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 11 Jul 2006 06:59:59 +0200
To: <grassuser@grass.itc.it>
Subject: [GRASS-user] how to create multiband/hyperspectral
Hello!
How to make it?
make it.
rasters as well...
Thanks for any help
Robert
Michael,
thanks, that’s really what I’ve found and thenks for your answer making it clear that there are no other tools for this.
My actual problem is to have e.g. 14 bands for a single area. I’m planning to play with displaying compisosite variations withount createing r.composite or r.rgb files for all possible combinations BUT - reading you answer finally I found what I need:
d.rgb :slight_smile:
I could easily drop in rasters (eg. bands) and play with my combinations.
thanks!
Robert
Robert Kuszinger wrote:
My actual problem is to have e.g. 14 bands for a single area. I'm
combinations.
i.oif may be interesting to you. Input data doesn't have to be LANDSAT.
Hamish
