Hello,
I've written a python script to generate an image combining a vector map (myvector) and a raster (myraster) that has been generated using a mask.
It works great by default and creates an image with the default dimensions 640x480 on a white background.
gscript.run_command('d.mon', overwrite=True, start='png', output=filename)
gscript.run_command('d.rast', map='{0}@{1}'.format(myraster, self.mapset))
gscript.run_command('d.vect', map='{0}@{1}'.format(myvector, self.mapset), color='white', fill_color='none')
gscript.run_command('d.mon', stop="png")
I would like to have a transparent background and to change the dimensions of the image to 1280x960.
Reading the documentation I had the impression that I just have to modify some variables, but it does not work.
os.environ['GRASS_TRANSPARENT'] = 'TRUE'
os.environ['GRASS_WIDTH'] = str(1280)
os.environ['GRASS_HEIGHT'] = str(960)
Thanks in advance for any advice.
Ciao
Jean Pierre Huart
Sorry I've forgotten to precise that I'm using Grass v7.0.3 on ubuntu 14.04.
On 08/03/16 16:15, jean pierre huart wrote:
Hello,
Ciao
Jean Pierre Huart
OpenJph
19, rue de la fontaine
1340 Ottignies
web: www.openjph.be
email: jph@openjph.be
tel: +32 487 95 77 75
skype: jeanpierre.huart
d.mon is designed for interactive use. If you're writing a script,
don't use it. Set GRASS_RENDER_IMMEDIATE=png (or =cairo) and use the
environment variables.
2016-03-11 13:36 GMT+01:00 Glynn Clements <glynn@gclements.plus.com>:
not really, beside wx monitors, you can use cairo or png (useful for
scripting). Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
scripting). Martin
You appear to be misunderstanding what "interactive" means in this
context. It doesn't necessarily imply a GUI.
The only situation where a script should be using d.mon is if it
really is a "script", in the sense of a canned sequence of commands
which is meant to be "replayed" as part of an interactive workflow.
Anything which tries to behave like a typical program should manage
the relevant environment variables directly.
2016-03-26 18:52 GMT+01:00 Glynn Clements <glynn@gclements.plus.com>:
scripting). Martin
I was just responding to your sentence "If you're writing a script,
don't use it."
Right. Ma
