[GRASS-user] How to delete small closed lines, problems with v.edit and v.generalize
Hello,
I'm trying to simplify a contour map I've done with r.contour. I want to remove small area but when I use the command v.edit map=<map> tool=delete thresh=1000 query=length, only "non-closed map" are considered and the "closed line" (there are really lines, not polygons) remain.
I've the same problem with the command v.generalize.
Does someone knows how to consider all the lines ?
Attached is my shp.
Regards
Lucien
(attachments)
Head_Interp_Rast_contour.dbf (10.3 KB)
Head_Interp_Rast_contour.prj (389 Bytes)
Head_Interp_Rast_contour.shp (128 KB)
Head_Interp_Rast_contour.shx (2.43 KB)
